Make sure your devices are not sharing one valid mac adress.
Lets Go !
This sites awful (the site, not the support, try to edit and it deletes the post lol).
Anyway, my IPTV stalker add on is 9.0.19.
My stalker PVR is 0.8.3
My stalker NFPS PVR is 0.8.3
The latter one has worked perfectly until today.
Update to the lastest one fill out the info save restart program.
Lets Go !
First, get the latest IPTV Stalker-mod (9.0.21) from the IPTV Stalker forum, and configure that first, with a new MAC, and the PVR Stalker disabled. Use those same credentials you created on the IPTV Stalker, and then configure the PVR Stalker identically. You then should have both working.
Where do I find the device ID or do I Create one. I have put information in for both device ID's and still get authorization fail. I put in a number for the signature and the custom serial number. I even reentered the mac address.
You create the device IDs and Signature. You do this on a fresh MAC, not one that has been used before, and configure it before making the add-on enabled.
I am also getting serial information invalid, bad or missing serial number. Everything was working until i updated to the version 9.0.21
