Darkside I downloaded the emulator to my usb stick and when I put it in the 260 box it does not show any where
What do I have to do can you help me very new to this
Thanks martys
Thanks martys
I think it's under inifiles?? You should be able to see the .apk file on the USB stick to install
I have the file on usb stick when I put it in may mag 260 it wont show so I can down load it
Thanks for the help martys
make sure the file is unzipped and then its somewhere in the menu(not in front of mine) but in the menu, if you have the correct file unzipped on the usb stick you should be able to see the file to install it... I think in the menu its called inifiles, its a folder in the menu or the home screen
darkside I have the file inst. any it shows authentication problem ant this is as all I can do
Thanks martys
did you input the url and change the mac address?
follow BIO'S instructions here... set up for the emulator is the same
http://iptvtalk.net/showthread.php?5...cussion-thread
Infomir has discontinued the 260 and the DVB standards for the 275 are basically for European, Asian markets, thks..
I do not speak either for MAG 260 or the OTA tuner of MAG 275, although reprogramming it to ATSC is not a problem . Not all Cable TV boxes need the tuners to decode the TV channels. MAG 275 is a Linux box and it all depends on the skills of whoever programmed it.
