I follow the tech instruction and did a manual factory rest but it didn't work .this is how I got mine working but I put a sd card in download the memory cleaner app and clean everything and i was good to go.
never tried that thanks
curious, for those stuck, how do they get to market to obtain the cleaner??
How do you download memory cleaner to sd card and will a thumb drive work the same. Thanks
just put the sd card on your box then go to the market place and download the memory cleaner
it doesnt give me the option to download to box or sd card and when trying to install from box i get same error message and it stays stuck on 0
Factory Data Reset
Having trouble with your box? Is something not working when it should? A factory reset might fix your problem. Both resets perform the exact same thing. Only use the manual reset if you cannot get the box to boot properly. BEFORE YOU CONTINUE, make sure to re-input your information when you start up the box for the first time. Also write down or save any information you might need, the factory reset will completely wipe your box of any saved data.
Regular Factory Data Reset.
Go to the settings tab in the main menu > Click on the pink system info button > Click on factory data reset.
Manual Factory Data Reset.
1) Make sure the box is connected to the TV by HDMI or RCA
2) Make sure the power is plugged out of the box
3) Push and hold the reset button with the pin for 10 seconds
4) Continue to hold it down and plug the power into the box
5) Hold the reset button for at least another 5 seconds and then let go
6) Proceed to wait for a bit while the box resets, it should open up again in console mode
7) Select the factory data reset option
8) The box will perform a factory data reset and reboot
9) It should then boot normally and start working. If it boots into the console mode again, make sure to just select perform normal boot up (I believe it is the first option)
my bad installed it
