Page 6 of 7 FirstFirst ... 4567 LastLast
Results 51 to 60 of 62
  1. #51
    No clock on the screen when you exploring channels..bad,bad bad
  2. #52
    Moderator at Work
    Just had a short time at home to try TvonlinePlus found it needed a factory reset then it did an update, now enter router code and went to channel store and put in OneChannel and Movie25 for now checked out ax few TV Andy Movies to see if they worked and they did, Put on two TV shows which had very good resolution and very smooth running, that was all I could do then next time I get to it will do the live channels.
  3. #53
    TV Addicted xbmcbg's Avatar
    Jun 2015
    xyz
    Quote Originally Posted by legsdiamo View Post
    Any idea when the Nova middleware will be available?
    When someone decides to make a new portal or to transfer an existing one on this platform
    none for now !
  4. #54
    Apr 2015
    I don't have HMI inputs on my projector .Dose this box support RCA inputs ?
  5. #55
    Super Moderator at Work catz's Avatar
    Yes...............
  6. #56
    Two of the greatest qualities
    to have in live are:
    PATIENCE
    and
    WISDOM
  7. #57
    Is anyone having trouble i have just got AVOV plus and it keeps locking up .Where i have to unplug it overnight before it will work.
  8. #58
    I haven't heard of anyone that that problem
    Have you tried a factory data reset
    Is your box very hot when it kicks out if its hot put in a ticket
    AVOV Submit a ticket here
    https://help.avov.tv/portal/newticket
    PATIENCE
    and
    WISDOM
  9. #59
    Have not tried factory reset when it locks up I can't power it up or down the blue and red light are solid.Not sure on how to install everything back in that was all done when I but it?
  10. #60
    Just plug it back in it's working for now thank I'll keep working on it P.S it seems to work great when it works HAHA
  1. Avov TVOnline Quick Review and First Impressions
    By speedymmx in forum aVOV TVOnline
    Last Post: 09-30-2016, 03:30 AM
  2. My TVOnline 4 Review
    By psycon in forum aVOV TVONLINE 4
    Last Post: 09-13-2016, 05:18 PM
  3. Avov TvOnline 4 My Review
    By Capt.Kangaroo in forum aVOV TVONLINE 4
    Last Post: 06-09-2016, 12:26 AM
  4. Avov TvOnline+ Review
    By Capt.Kangaroo in forum aVOV VIXO1
    Last Post: 10-06-2015, 01:46 AM
  5. Avov TvOnline+ Review
    By Capt.Kangaroo in forum aVOV TVOnline
    Last Post: 10-05-2015, 11:40 PM
