same thing, IPTV are showing Technical Difficulties.
TvOnline = v1.42
TvOnline = v1.42
OK so it is not just me............thank goodness.......I don't have to suffer alone.......
then why is mine working only two have that ?and only one yesterday
Wish I knew ............................A while back my Avov would not work at all and I had to contact the company and they needed the S/N of the box.....so they could add it to the list in their servers..........hope this is not something like that........looks like they can drop you at anytime by deleting your S/N of the box on their server...........
If down have you tried taking power off router for at least one min, hard to know why some oK and others not.
tried rebooting modem and router.........may try disconnecting for a while and see what happens
If you can not get it going can you take to another location to try?
Yea..i may have to do that............Thank you all for your help.......
Back then is when they moved servers they left some serial numbers out- it seems. The apps on the box worked but you could not install new apps.
I never had the problem here but now seems like maybe the update isn't working. I just checked mine and it seems to be working on channels fine. They can drop the connection to their server but being able to install the app again suggests to me that is not the case this time.
I still think it's the type of problem that will be fixed on their end when they work on the server again.
