Page 7 of 7 FirstFirst ... 567
Results 61 to 67 of 67
  1. #61
    What you do is to copy what settings that are in the appropriate file (for your ram) into your current advancedsettings.xml. If you didn't have an advancedsettings.xml, you would rename that file to that.
  2. #62
    Apr 2016
    Thanks. What I did was copy the values from the OP file into my advancedsettings.xml file, replacing those values which were there originally with the new ones, as well as adding the other stuff. Is this correct?
  3. #63
    Quote Originally Posted by nickhack View Post
    That should do it. Just be aware that this isn't a cure-all.
  4. #64
    Apr 2016
    Well I did it, I think, and I honestly dont see any improvement. Anything else I can check?
  5. #65
    Jun 2016
    Yep
    Constant buffer through the whole fight this evening...
  6. #66
    Sep 2016
    File does not download. Can you please attach again
  7. #67
    You can search for the file on Google. You need to choose the file that is consistent with your device's ram, i.e., I Gig vs 2 Gig.
  1. Constant buffering
    By lougump in forum BuzzTV XR/XRS4500 - XRS4500 MAX
    Last Post: 04-08-2022, 08:19 PM
  2. nfps constant buffering
    By Longfin in forum Dreamlink T1 Plus
    Last Post: 05-29-2019, 12:26 AM
  3. Constant Buffering on some Channels
    By caribchief in forum IPTV Private Server (IPTV66)
    Last Post: 05-28-2016, 07:33 PM
  4. Avov TvOnline+ Constant Buffering
    By dachampko in forum aVOV TvOnline+
    Last Post: 02-07-2016, 06:56 PM
  5. Constant Buffering
    By bmor10 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 01-26-2016, 05:00 AM
