Wish infomir can come up with something similar for the Mag's!! Good Job!
Relocate Puerto Rico Channels WKAQ-TV(7781) to Channel 2 , WAPA-TV (7782) to Channel 4 , WIPR-TV (7783) to Channel 6 & WLII-TV (7784) to Chanel 11.
the mags work fine.. even with this fix, kodi works no better than a mag... if a mag freezes, kodi will freeze.. this fix resolves an issue where kodi devices buffer far much more than mags due to the lack of a playback buffer.. mags already had that built in.
the freezing you are wishing away is either server side, or a problem with your internet conenction..
I'm not comparing or not satisfy with the Mag 254. Just like to mentioned that I have (2) Mag 254 (1 with r10 & the other with r12) side by side with (2) Androids 4mb 16ram with latest Kodi and this xml file with 20 meg Cable internet and the Mag freeze more often than the Androids. Androids has more tweaking and around the corner trick to ease the freeze problems. To me both are pretty good boxes. I still keep my Mags as my main boxes.
nice thanks for the comparison.. I have not done extensive testing between all the boxes side by side really.
I did jsut find out my ISP makes the connection choppy as hell.. the UFC was freeziing on and off constantly... switchted to my VPN connection and everything is working flawlessly.. my VPN provider is PIA, if anyone else wants to give that a shot. ( no i am not seeking referrals, or have anything to do with them, just an honest suggestion)
Is there a mistake in some files?
I see in the respective files:
1GB: <cachemembuffersize>39321600</cachemembuffersize>
2GB: <cachemembuffersize>78643200</cachemembuffersize>
4GB: <cachemembuffersize>314572800</cachemembuffersize>
8GB: <cachemembuffersize>78643200</cachemembuffersize>
Shouldn't it be something like this:
4GB: <cachemembuffersize>157286400</cachemembuffersize>
8GB: <cachemembuffersize>314572800</cachemembuffersize>
Nice catch. I updated the file on the OP here: http://iptvtalk.net/editpost.php?do=...t&postid=64477.
Psycon: can you update the file please..
Is stalker client down? Channels not loading
Loading channels/guide slower but working fine!
i dont see anything ?
