Results 1 to 6 of 6
    Yes I do
    Setting up PVR to work with IPTV Stalker
    Hello everyone.. hopefully not repeating a previous post as some were similar but nothing 100% same issues as I am having.. I did donate so I have access to all IPTV Stalker channels which is fantastic.. I have tried using iVue Tv to work as a guide and even under the app settings for channel list I clicked Stalker and it still brings up just the general channels and very few of the IPTV ones. I have tried using IPTV simple PVR and followed guidelines in regards to channels and ECM, etc but still just loads the same channels it normally does and very few even work so definitely I am missing a step or something from when I set up the PVR to have it connect with my IPTV stalker so I can access all the channels I normally do but through a EPG.
    Any help would be greatly appreciated.
    tux tux tux
    Jul 2015
    in my head
    why don't you use the pvr.stalker that comes with kodi with the xml epg? then you will have proper pvr function in kodi -(minus)recording.
    Yes I do
    Thanks for reply.. well I believe I have done that previously.. I am guessing it has to do with the settings I am using.... is there a way that when I use the pvr stalker and epg that it ONLY brings up the IPTV stalker channels and no other ones? That is kind of what I am looking at as every single one I have tried doesn't bring up the IPTV stalker ones
    They both have the same channels please do some reading in the forum and you will see the difference
    Yes I do
    Thank you very much.. I think the issue I have ran into is taht I am still running the KitKat version of Kodi so maybe upgrading to Isengard which seems like alot of people are saying is way better and solves alot of issues is my best bet.
    KitKat? That's an android version. The recent versions are Frodo (12.x), Gotham (13.x), Helix (14.x), Isengard (15.x), and upcoming Jarvis (16.x).
    IPTV Stalker will work on Gotham and above, but PVR.Stalker needs Isengard if you want an EPG.
  1. Setting up MXQ Android with KODI Jarvis to work with Rocket or NPFS IPTV
    By sun47me in forum Kodi Tutorials, Tips & Tricks
    Last Post: 08-16-2016, 08:47 PM
  2. Replies: 4
    Last Post: 07-06-2016, 03:24 PM
  3. Setting up IPTV Stalker
    By fullautoten in forum IPTV Stalker (Video add-on)
    Last Post: 01-17-2016, 04:27 PM
  4. Problems setting IPTV Stalker Kodi 15.0
    By rlant in forum IPTV Private Server (NFPS)
    Last Post: 09-05-2015, 12:55 PM
  5. Setting up IPTV Stalker and PVR Stalker for paid access.
    By dara in forum Kodi Tutorials, Tips & Tricks
    Last Post: 07-25-2015, 03:03 AM
Tags for this Thread
