Hi guys, first post here and the first thing I'd like to say is thank you, especially to Dara. Without these forums I wouldn't have been able to learn/figure out/fail/retry nearly as much as I have.
I've only been at this for a week, I bought a months sub. via IPTV66 to test it out and see if I could get it all working. After many failed attempts and much digging through these forums I've been able to successfully set up iptv66 with working iptv simple client pvr and I have a sweet working tv guide
However, I've noticed recently that the Ivue guide appears to be more accurate in terms of times/shows alignment (for me at least) and I'd like to be able to get it working as well.
Currently whenever I run the Ivue guide it opens up no problem but when I select a channel I get the "mac" error (even when manually selecting the stream). I know that all of my settings are correct because everything else is working. I've done my cache clears, xml deletes, mac changes, but I can't seem to get past it.
I'm running iptv stalker 1.0.18 as it seems to be the only one I can get working with the iptv simple pvr client. If someone could direct me in the appropriate direction to get this working it would be much appreciated.
Thanks again!
