Results 1 to 10 of 10
    Jan 2015
    volume control on mag 254
    The blue volume won't go down, need to use remote for tv
    alphaaaaaaaaa alphablondy's Avatar
    did you check the batteries on your remote?
    Jan 2015
    Yes the batteries are brand new as is the receiver I can change channels and everything else works great. Volume is stuck wide open
    Super Moderator BIO's Avatar
    Do the right and left arrow buttons do anything?
    Up and down should change channels, do they do that?
    You can check that your remote is transmitting by looking at the front of it through the camera of your cell phone. Will see the bulb light up when sending signals.
    Moderator at Work
    See what you have in audio settings.
    Jan 2015
    The mag254 's blue light led blinks when a button is pushed..
    Quote Originally Posted by BIO View Post
    Jan 2015
    all buttons work as they should
    Check them out and even the blue light flashes when using remote. Anything else audio settings are good as well.
    has your stb been updated?? what revision of 218 are you running?
    Jan 2015
    218 version
    Quote Originally Posted by K00lKatT View Post
    2.18 r10-254
    Rocket Recovery Technician
    did you go to the inner portal, and check the settings for audio? there is an icon in the lower tier right side of the main inner portal menu that is full of instructions, and setting information.
  1. volume control for terrestrial
    By whatshapp in forum Dreamlink T3
    Last Post: 05-25-2020, 04:40 AM
  2. Volume Control Mag254
    By juan_vale in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 03-14-2017, 04:55 PM
  3. Volume control
    By hjr007 in forum Dreamlink T1
    Last Post: 01-16-2017, 04:47 PM
  4. volume control
    By mikenav in forum OTT M8 4K Android TV Box
    Last Post: 01-01-2016, 07:56 PM
  5. Volume control
    By mikenav in forum Kodi Discussion
    Last Post: 10-09-2015, 02:10 AM
