Hi everybody is there someone as can tell me why the "YOUTUBE" is blocked on MAG254 with image 218-R11 ?
I just tried mine it is working fine are u using the inter portal one or the outer portal one I did not try the inter one
Well , do you mean system settings / servers / portals / portal 1 url = thats what i use. ( sorry i'm a newbie ).
no, he means go to the inner portal, you can do so by menu or click set up button on remote
Ops sorry -
Yes, i've tried bouth and nothing works i get all the time the ERROR PLAYING : YOUTUBE BLOCKED THE VIDEO TO VIEW FROM SET-TOP BOX .
Some videos may be blocked at the source try a few others.
That's very strange i've tried even with my youtube account, and even there i get the answer ( YOUTUBE BLOCKED THE VIDEO TO VIEW FROM SET-TOP BOX . )
this is a you tube issue, not a fault with your box..
It all depends what video you want to watch.
Lets Go !
I tried Youtube on inner and outer and both worked with no failures using rocket, try ENYA in a search although all I tried were active.
