So this fixes the constant buffering and stop and go on live tv?? It's getting rather annoying.. I was watch Cricket, and it kept stopping and going.. I don't know if this fixes the sync issue with the voice offset. Thoughts?
Please do not make these changes unless you understand what you are changing. It could make things worse. Hence Advanced settings. Your cache buffer size will be determined by the amount of memory your device has. Other settings will be determined what type of device you have so for example you would not want buffer to disk if you have a flash drives do to the constant reading/writing which will cause the flash drive to ware out more quickly. Instruction can be found on the Kodi Wiki.
Hi guys, is there any official word from rocket regarding the ETA to fix this issue?
Here is better instructions
First Install the Easy Advanced Settings program plugin for kodi from Super Repo. (google how to install super repo)
Then....
1. Open the Easy Advanced Settings plugin, then go to Edit settings > Network >Network
2 . Set as follows;
<buffermode>1
<cachemembuffersize>419430400
<readbufferfactor>4.0
3. Back out until you see Write XML and choose it.
4. Restart kodi.
The readbufferfactor is what helps with live streaming I've found while testing.
