Ok this advanced setting did wonders for my Rocket's buffering so I thought I'd share with the Rocket Team. This is for my Stalker PVR Client that has fixed freezing for me so let me know if it helps you as well and if so sticky?
Ok its just a simple advancedsettings.xml file with the following settings inside....
<buffermode>1</buffermode>
<cachemembuffersize>419430400</cachemembuffersize>
<readbufferfactor>4.0</readbufferfactor>
The easiest way to install this correct is with the program add-on for Kodi called "Easy Advance Settings" that will make and install the file properly. The add-on is straight forward so I don't think I need to explain that. Just once you got the
advancedsettings.xml file installed reboot to see effects.
Now let me know if this is working for you also or did my box pull a miracle?! haha... Cheers!
