Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
    Question Authorisation failed
    hello all , have my Amazon fire TV all set up and going 2 days ago , I have tried to update to the 9.019 and put my MAc address assigned to me and cleared the .XML in file manager set everything to default, i have noticed now send seriel number is gone now , its cost me Alot of money to join here being 1/2 way around the world from the USA and am very fruetrated and dis satisfied
    HELP HELP HELP.............................................. .
    NFPS Error
    I just donated, I set up my Mac and followed instructions but none of the live TV is working. I get authorization error once I click a channel in NFPS, I am using IPTV stalker in fire stick with Kodi, are the servers down or does anyone have a fix, thank you
    Help for a newbie
    hi guys looking for a little help I've made my donation and followed every tut i could see and i still get auth failed
    i have reinstalled kodi to latest version and also iptv stalker
    i insert my mac i clear the cache but i get nothing.
    just auth failed please am i missing something
    all help appreciated
    I'm having same problem...changed the Mac works for a minute then get the error again ..not sure what's going on..can anyone help here?
    http://iptvtalk.net/showthread.php?7...Vue-compatible
    If you are trying to run more than one connection, you probably will get auth errors. If you got a MAC but no donation number, sorry, can't help there...you need to have a MAC that is linked to a donation. If you are running PVR Stalker, make sure you didn't make any changes there where you are sending a serial number or password, whatever.
    Dara, i'm not doing any of the above and do have a donation, changed my mac for the 4th time and still got the error message ..need help please.
    You don't have to pm me. If you are following the steps, you may have an install issue, so uninstall, and reinstall IPTV Stalker.
    sorry dara, didn't mean to bother you thru pm..but how can i access the settings.xml file on android box do you have the path to that file ?thanks
    Quote Originally Posted by macsol View Post
    Post #2 ... do it through Kodi... its easier.
  1. ITV authorization failed ?
    By Carli in forum Kodi Discussion
    Last Post: 02-28-2016, 04:07 AM
  2. authorization failed
    By visigoth in forum IPTV Private Server (NFPS)
    Last Post: 09-27-2015, 03:04 AM
  3. HELP PLEASE, Authorization failed????
    By br7830 in forum IPTV Private Server (NFPS)
    Last Post: 09-26-2015, 07:49 PM
  4. Authorization Failed
    By Th0mas in forum IPTV Stalker (Video add-on)
    Last Post: 09-22-2015, 03:03 PM
  5. Authorization Failed
    By ig1151 in forum IPTV Private Server (NFPS)
    Last Post: 09-18-2015, 06:42 PM
Tags for this Thread
