Results 11 to 20 of 30
    Quote Originally Posted by ptale0515 View Post
    I'm having Authorization Failed error as well on some channels. I went ahead and changed my MAC address, and still have the Authorization Failed error...
    What to do next?
    See post #7.
    See post #7.
    Hi Dara!
    Where's post #7?
    This is a big issue. Almost all the channels do not work. Keep receiving "Authorization Failed" error...
    Go back to the first page of your post and go to the 7th post with my post you have 13 now
    Help! Lost all channels since Stalker update, Authorization Failed, I've changed mac address, cleared cache etc & still the same error.
    Kodi 15.1 on Android box. Am really stuck.....
    Tried changing mac address again, on papiao & on stalker, cleared cache etc but still nothing just Authorization Failed???
    Any help greatly received
    Also which portal is best? 11.iptvprivateserver.tv/ or portal.iptv etc?
    I know people have been saying 11 but portal was working fine before stalker update..
    yes i do.
    Excact same problem here. Have followed all instructions but can't get anything. Is there a way to get rid of Stalker update & go back. All was working fine before
    Problem all sorted by deleting old settings.xml file. )
    Quote Originally Posted by WalkinDude View Post
    Same here. Defaulted the addon. Changed Mac addy, cleared cache.
    Nada.
    Where is the old settings.xml file i need to delete?
    Thanks!!!
    I'll summarize the steps necessary to not have the authorization fail. You need to have a current donation/rocket/route... if you got a MAC only from a reseller, go to back to that person for support.
    1. Go to the donation checker for the service that you have and modify your current MAC. Your first 6 digits are 00:1A:78, and modify one or two of the last six digits and save. If it doesn't take, try a different MAC.
    2. In Kodi, go to File Manager, select Profile directory, addon_data, plugin.video.stalker and delete settings.xml
    3. Go to the settings for IPTV Stalker, and enter the new mac in your appropriate portal. Those who are got this addon automatically were using the iVue repo, so you will also need to put the mac in Portal 1.
    That should be it. If you still get the error, repeat steps 1 and 3. You should also be able to use the new MAC in PVR Stalker, the STB Emu and the Official Android Emulator. If you have a MAG, you shouldn't be using its MAC on the Kodi apps, because you can't change it, however, if you can make it work, good for you!
    Ok WORKING
    What a load of fiddly b****x
    Thanks dara. Your tips worked with a tweak.
    " 1. Go to the donation checker for the service that you have and modify your current MAC. Your first 6 digits are 00:1a:78, and modify one or two of the last six digits and save. If it doesn't take, try a different MAC.
    3. Go to the settings for IPTV Stalker, and enter the new mac in your appropriate portal. Those who are got this addon automatically were using the iVue repo, so you will also need to put the mac in Portal 1."
    All that BUT!!!
    Note! When you default the updated addon it sets the first six digits to this 00:1a:78
    My mac as most folks the first six digits are 00:1A:78. It wouldn't let me via the https://papiao.is/main/search_nfps mac change site change the CAPIT A to a lower case a :/
    So when i changed to a capital A inside the kodi addon it worked.
    Deary me. Hassle!!!!!
    Thanks again for the info.
  1. itv authorization failure
    By jetsr in forum IPTV Private Server (NFPS)
    Last Post: 03-04-2016, 12:59 AM
  2. Authorization Failure AGAIN! smh
    By dafatmack in forum Kodi Discussion
    Last Post: 10-28-2015, 08:22 AM
  3. Authorization Failure AGAIN! smh
    By dafatmack in forum IPTV Stalker (Video add-on)
    Last Post: 10-28-2015, 08:05 AM
  4. Is IPTV down?? getting authorization failure
    By rhabr in forum PVR Clients
    Last Post: 10-20-2015, 03:33 PM
  5. help iptv authorization failure after update to 9.0.19
    By 817smoke in forum IPTV Private Server (NFPS)
    Last Post: 09-03-2015, 12:13 AM
