Results 1 to 5 of 5
    Jan 2015
    "Authentication Problem"
    Hello all, I am getting "Authentication Problem" when I try to load rocket portal. The blue screen comes up with the bar in the middle, about a 1/4 of the way up the yellow shows up, freezes there and gives me the error. It was working, channels working last night. Internet speed good, connected when I checked this morning. Box got updated to r11 release. Help please!
    If it started after the update? Reboot the box and recheck you setting
    Jan 2015
    Hi big dady, I did reboot. Even unplugged and plugged back in. The update was done after I established an Internet connection. Then i did all remaining settings as far as servers. Why was it working last night, with hardwired in. Try this morning and I get the error. Thank you though.
    Android World
    The service has been like a roller coaster over night so do not adjust anything.
    Lets Go !
    Jan 2015
    Hi bkman2020, I think that's what I'll do. Leave well enough alone and just check every so often. Thanks!
  1. Errors when rebooting - "Authentication" and "Unable to load channels"
    By adrenochrome in forum IPTV Private Server (IPTV66)
    Last Post: 02-20-2016, 09:31 PM
  2. "Authentication Problem #2
    By cams in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 09-14-2015, 01:34 AM
  3. "Authentication Problem" Initial Set Up MAG 254
    By rp1230 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 09-11-2015, 08:20 PM
  4. "Authentication Problem" Initial Set Up MAG 254
    By rp1230 in forum Introduce Yourself
    Last Post: 09-11-2015, 06:16 PM
