Page 3 of 30 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 294
  1. #21
    Jun 2015
    It freaking works lol ...... Great work Dara Thank You
  2. #22
    Sorry folks, there was a bug we found in testing for new installs of 9.0.19, so if you had gotten it earlier, please download it again and reinstall. It shouldn't affect those who were simply upgrading.
    ivueguide and I were testing this, and he found the bug. Good news is that he'll push this to the iVue guide repo, after he tests it on his own, so "everyone" will have the modified IPTV Stalker that has the iVue repo.
  3. #23
    This is the best new I heard all week... Dara you rock!!!! Great job collaborating with techguide
  4. #24
    Jan 2015
    Thanks Its Working !!!!
  5. #25
    Quote Originally Posted by Mumalo22 View Post
    I checked tec repo and IPTV stalker is not his repository or part of his wizard. I look forward to when it will be uploaded. Muchas gracias..
  6. #26
    My add-on will not work if send serial is not checked it will work if send serial is checked tried with new Mac address,stalker modified and still no go I guess mines has to be checked
  7. #27
    Quote Originally Posted by dphi931 View Post
    The fix is to use a new MAC. This will also allow you to use the PVR Stalker addon and the STB emu.
  8. #28
    I'm looking into making it easier for ivue to clean up their addons.ini to minimize necessary data transfer. It's his call to put it on his repo, because that will affect a lot of people... especially those who were connecting with the serial number being sent.
    I found another issue in the code that wasn't allowing the channel logo to be seen when you are playing a channel. I have a fix, but because it's trivial, I'll hold off before sending it out to get feedback for 9.0.19.
  9. #29
    I did use new Mac and still get authorization failed followed all steps uninstalled stalker 1.2.0 installed 9.0.19 clicked on defaults entered new Mac address clicked ok entered stalker add-on clicked on channel authorization failed did I miss something?
  10. #30
    You might have downloaded a version that didn't work if installed from scratch. If you are on a PC, go here to delete the current settings.xml, and reconfigure.
    c:\users\your user name\AppData\Roaming\Kodi\userdata\addon_data\plug in.video.stalker\
  1. Replies: 6
    Last Post: 10-26-2017, 11:20 PM
  2. Replies: 4
    Last Post: 04-06-2016, 01:57 AM
  3. AVOV box with IPTV Stalker VS Kodi with IPTV Stalker
    By bradtn in forum Kodi Discussion
    Last Post: 09-05-2015, 12:34 AM
  4. Android Box w/ Modified Kodi + Stalker0.5
    By mcpuffins4 in forum Android TV Boxes
    Last Post: 04-03-2015, 05:56 PM
