Results 21 to 30 of 36
  1. #21
    i didn't think we could update manually. I was seeing if the poster Lowtech was actually able to downgrade based on his writing. All we can do is wait for AVOV to fix the issue. I am quite surprised it hasn't been addressed by now. Has AVOV given any update recently of the 1.07 issue? thanks
  2. #22
    i have never see anyone downgrade
  3. #23
    This is the ticket response I got yesterday
    you may want to put a ticket in on this issue
    https://help.avov.tv/portal/newticket
    the more tickets they get the better off we are
    Thank you for your response, I will notify the engineering team of this. We will get this resolved as soon as possible. From my understanding the build issue should have been resolved. The team will be online in a few hours and please let me know on Monday if it has not been updated.
    Two of the greatest qualities
    to have in live are:
    PATIENCE
    and
    WISDOM
  4. #24
    Quote Originally Posted by Lowteck View Post
    If you do a factory reset and let the box do the auto update then if 107 has been removed then you should stop at 106, but if it goes back to 107 when it does the auto update, then turn off the auto update and manually update until it show 106. Hope this helps you and others.
    I didn't think you could but Lowteck seemed to think you could I was out in the field harvesting so when i got home i had to give it a try
    Not sure if your box had a lower version on and you did a factory reset if it would go back to the original build or not
    if it did it may be posable to update to a lower version unless it goes straight to the latest version
    Ours being a new box the oldest build it could ever go to is build 1.0.7 on a factory reset anyway
    PATIENCE
    and
    WISDOM
  5. #25
    look you cant well you could if you had there apks which they would never give out to reset so your sol till they fix this sorry you guys have all this bad luck on this one they should have never sent that one out really cant see why the channel store cant get it for you to add kodi 15.2
  6. #26
    It's not all bad if all worked I may have just plugged it in and sat back. This way I have become active in this form.
    I strive to keep members up to date on the progress on build 1.0.7
    PATIENCE
    and
    WISDOM
  7. #27
    Pinball Wizard
    I'm still try to get my head around creating a device with 2 different builds specially one that is does not provide the full potential of this device. My take as a developer is to create a device and have them all sync into the same build so that is easier to solve any issues and simultaneous future upgrades . I was lucky to have the 1.0.6 and love my device, if they are unable to fix this issues they should at least provide a patch (firmware) to the lower 1.0.6 so that the users that bought this device are not waiting to fully enjoy this device. I do know that they are working hard but at some point you have to sync all Vixo 2 to the same firmware!!! IMHO
  8. #28
    i would say so dont know why they did that but im not them bad move on there part i;m running 1.0.6 and david is gone now we have hans hope you get this fix soon avov been what a month now
  9. #29
    I am sure releasing these with build 1.0.7 was a total screw up
    I thing build 1.0.7 should and still is in the test stage or why have they not updated them all to this build
    PATIENCE
    and
    WISDOM
  10. #30
    Starting to get a bit frustrated!!!!! This issue was first addressed by david_avov on the 08-17 and there was been no changes to the issue what so ever still missing 8 channels
    They keep telling me they are working on the issue and thought they had Kodi fixed ,I would think they would have a box with build 1.0.7 to try it on so they could verify it is working
    Still waiting on a reply to the email i sent them last night
    PATIENCE
    and
    WISDOM
  1. EPG Missing Channels
    By georgec in forum EPG (epg.ninja)
    Last Post: 04-19-2016, 08:07 AM
  2. Vixo2 and Vixo2 Maintenance
    By tinieBlax in forum aVOV VIXO 2
    Last Post: 02-05-2016, 02:31 AM
  3. Imposibled to see channels in my vixo2
    By pedrer in forum aVOV VIXO 2
    Last Post: 02-05-2016, 01:58 AM
  4. Has anyone with the VIXO2 build 1.07 get it fixed
    By Farmer1 in forum aVOV VIXO 2
    Last Post: 09-17-2015, 10:51 PM
  5. Missing KODI app on vixo2
    Last Post: 08-11-2015, 06:16 PM
