Paired a bluetooth keyboard via the settings pairing menu and although it's recognized it doesn't let me click on the menu.If ur interested in how to get STB Emulator working... Try this;
Download 6.11.... Either pro or non pro are the ONLY ones that work. Only difference is adds on free and no adds on pro. Download it, side load it with ADBfire.
Download another android app called "settings". It will make it easier to do bluetooth pairing. - the issue you speak of is because that menu (after pressing the button with three lines) is only navigable by external keyboard/mouse. Also, you can only get this menu up once... So you'll need to restart the app if you need it again. anyway, use settings app and pair your stick with your PC or something. Then bring up that menu and click the settings option.
From there, it's pretty easy. Set your MAC in profile, set your server Url - 11.iptvrocket.tv (not portal like Kodi... It's 11 like a box)....save and close.
You should immediately restart the app... Goto that menu again... Click multimedia player and choose internal.
Your pretty much done with the hard stuff... The rest you can easily figure out. It absolutely does work though. The trick is the bluetooth mouse/keyboard pairing.
Good luck!
