Results 11 to 20 of 25
    its you start reading more follow it to T you know with mouse its top right and bottom for info and setting when in emulator
    Ambassador DarkSide's Avatar
    when you load it through usb, and click on the file after it is unzipped, a window should pop up, you can pick pkg installer and that should install the app
    Super Moderator BIO's Avatar
    Quote Originally Posted by DarkSide View Post
    mine is vassilchmax as well... what version is the one you linked BIO?
    I have to look
    Apps says 0,5,18, so does download file
    Says 4.9.9.(image version: 216) at the bottom when loaded.
    your is latest i seen Bio have tried the other one too and few more wish they come up with new mag 254 version but don't know if that make a difference
    Quote Originally Posted by danemer View Post
    "Free" version of "vassilchmax" (IPTV Set-Top-Box Emulator by Maxim Vasilchuk) wouldn't load. Said something about compatibility issues with my system/device and then a copyright complaint when I tried to get it via
    htpcguides.com
    . Spent all day trying different apps and such but - NO LUCK!! Still haven't been able to find out how to load an app via the USB port either. It wants me to use an app for that too!
    Hate to have to return this box. It's supposed to be better - at least as far as RAM/flash memory and such.
    HELP ME - I'M DROWNING!!
    HOW COME THIS SITE KEEPS DROPPING MY LOGIN?
    When you login next tick the box that says keep me logged in and it should keep you from timing out. I coded your outside link for ya a bit ago
    I looked for days to find the one loaded, trying everything I found along the way.
    Dark, what version did you find because it doesn't say in the filename?
    0.5.14.. but my image version matches yours..
    4.9.9(image version 216)
    Give the new version a try, it has some improvements
    just installed it!! thanks!
    yup BIO yours is best so far
  1. Mag260 and cannot get the portal to work
    By Viti in forum MAG 260
    Last Post: 01-09-2017, 07:53 AM
  2. Replies: 1
    Last Post: 01-18-2016, 06:15 PM
  3. mag260 has epg now
    By Marley in forum MAG 260
    Last Post: 05-05-2015, 05:49 AM
  4. Mag260 Android Box...
    By rorrin in forum Other Devices
    Last Post: 04-27-2015, 03:03 AM
