I keep getting the error device mismatched id when I try and link the epg
You need to use 00:1A:78 not 79 for mac address
I am using the stalker PVR add-on and it says to use the last 3 hexidecimals groups linked to your donation. When I add these hexidecimals numbers in I either get a authentication error or the device ID mismatched
My donation starts with 00:1A:78
Are you using or have used IPTV Stalker as well? Did you ever click "Send Serial Number" or ever put data in fields in PVR Stalker besides the portal url, MAC or XMLTV?
Did you clear data after disabling "LIVE TV", and made sure you disabled "Stalker Client" in the PVR Clients list?
I have IPTV stalked installed and using it don't have serial number sending enabled, I thought I was supposed to use PVR stalker
You might need a new MAC linked to your donation. Don't use iVue, and make sure you aren't using 1.2.0 for IPTV Stalker... i
Where is the new IPTV stalker repo
