Page 9 of 9 FirstFirst ... 789
Results 81 to 89 of 89
  1. #81
    hi where can i get the latest version of stalker client nfps for kodi 16 javis the version i have wont install thanks
  2. #82
    Quote Originally Posted by spiroG View Post
    http://iptvtalk.net/showthread.php?7...ll=1#post56678
    The first post of this thread also has the same link.
  3. #83
    Feb 2016
    yes I do
    Setting up Stalker. I read the posts and feel confident that I entered everything right. When I hit open, I get, "Doesn't recognize Mac". Went to checker and did a reset. Did not work. Should I change Mac in checker to just the last 3 pair of letters/numbers?
  4. #84
    I'm not sure what you are asking. The Mac in the Donation Checker is the Mac that you enter in PVR Stalker client. The only numbers that can be changed are the last 3 cuplets. Your Mac must begin with 00:1A:78. If it begins with anything else, you will not be able to authenticate.
  5. #85
    Quote Originally Posted by zipp View Post
    Different addon... you are describing IPTV Stalker.
  6. #86
    hi again i get this message when trying to install the latest version of stalker on kodi 16 on firestick failed to install addon from zip any way around this thanks
  7. #87
    Not really, it is a problem for some with the firestick. There are those who have been able to get it to work, look in the Amazon Fire TV subforum for help.
  8. #88
    Apr 2016
    Earth
    I have problems with PVR Stalker... every time I point my remote URL to ********** it works. But then it breaks and it changes to a local URL which never loads. I have to change it back every time I start Kodi. It's aggravating! Hopefully I can get IPTV Simple to work since Renegades and iVue have both shut down because of some douchebag in Louisiana.
  9. #89
    Jun 2016
    Iv'e been having the following issue with the latest PVR Stalker NFPS on Kodi 16.2. The Add-on loads fine, authenticates and downloads the guide(takes some time) im able to go into individual channels an watch however whenever i try to open the guide kodi crashes and exits. I have cleared the kodi app cache on android and cleared the TV guide cache with no luck. Does anyone know whats happening? How to fix this? Thanks
  1. Droid setting and Stalker Client!
    By Lowteck in forum IPTV Private Server (Rocket)
    Last Post: 11-03-2017, 08:24 PM
  2. Help Setting Up Stalker Client
    By Petrucci in forum PVR Clients
    Last Post: 05-09-2017, 06:35 PM
  3. Replies: 12
    Last Post: 10-25-2016, 03:01 PM
  4. Setting up PW in Stalker client NFPS
    By prnnath in forum PVR Clients
    Last Post: 03-07-2016, 01:59 PM
  5. Problems setting up epg for stalker client
    By abbytanis in forum IPTV Private Server (NFPS)
    Last Post: 12-11-2015, 09:14 AM
