check for typo's in epg link,its case sensitive.
Strange! I used the same 0.8.3 plus *.zip PVR Stalker file for both. All EPG info should be there. I will factory reset this one, any other idea? I'm afraid to do a Factory, recall what happens to my Mag254 erasing the Infomir logo because of a factory.
Relocate Puerto Rico Channels WKAQ-TV(7781) to Channel 2 , WAPA-TV (7782) to Channel 4 , WIPR-TV (7783) to Channel 6 & WLII-TV (7784) to Chanel 11.
or XMLTV Scope, Select one of the following : Prefer XMLTV, XMLTV only, Prefer Provider, Provider Only
If you select an external EPG, select Remote URL and enter one of the following
Valid EPG Links:
Hey thank you for the help. Without people like you id be completely lost lol. Now, what do you mean when you say "external EPG"? I want everything inside of the Stalker NFPS Client if possible to keep it as simple as humanly possible for my 65 yr old father to use, is there a way to see whats currently on underneath the channel name? I am sooooo close to having it fully set up but am having difficulty with the guide.... it doesn't tell me what show is on each channel and it doesn't bring the guide up for me but the stalker nfps client is working when it comes to playing the actual channel.... any advice?Code:http://**********/NFPSF.xml - Complete guide for all languages http://**********/NFPSE.xml - Guide for English Language Channels http://**********/NFPSFD.xml - Complete guide, for those who do not observe Daylight Savings Time http://**********/NFPSED.xml - English guide, for those who do not observe Daylight Savings Time
I don't know what ur referring to but if you setup and are getting epg information it will be as what ur askin for(currently playing program under channel name).
Ok, finally I found where the guide address was supposed to be enter and added : http://**********/NFPSF.xml - Complete guide for all languages. Now I have the guide!!! I do noticed the system slowing a bit in response. My very last question on this matter will be,
since the channel and EPG loading when opening Kodi takes some time , is there anyway no to Exit Kodi when not in use so you dont have to go all over again the process of loading the channels/guide? I recall seeing my laptop some additional features with Exit such as Suspend, Hybernate, Reboot etc ??? This Kodi Android is only giving me the Exit option. Another trick for this?? Thanks everyone for all the help!!
Hello
I need some help. Once I runs Kodi the PVR stalket loaded fines. Then, it loads a small guide, following with Ïmporting Guide from Clients"Golden premier 1"and it suddenly stop right there and nothing else happens. I can go to TV and see all the channels but still having issues with the guide. Can someone help?? Thanks"
wait,it takes a bit to load.sometimes minutes for me.there alot people downloading from server and u may have to wait your turn.
I can't seem to find the right location to where I can enter this url -->> http://**********/NFPSF.xml
