fro the bottom of my heart ty... [ trowing sats to the garbage.. ]
How should I have my guide settings set up with regards to update interval and days to display? does it matter?
Hi , my linked MAC = 00:1A:79:xx:xx:xx .... stalker is working , but i get authorization failed using this howto
Your linked mac should be 00:1A:78:XX:XX:XX not 79...
How do you adjust the EPG Time offset with this version of the client?
Are the PPVs channels working Dara? I have all 919 channels loaded and most if not all except the PPVs channels not working. Running PVR Stalker 0.8.3, on Linux.
they work right now for me.. didn't try all san andreas, insidious, war pigs, and a few more worked fine..
Why I'm only seeing a small square box and not a complete screen after installation?? Can't find any way to fix it? What do I need to do to configure?? Thanks
Edited:
After I did some reading found out the answer unchecking the first box in the video/acceleration, Thks
Relocate Puerto Rico Channels WKAQ-TV(7781) to Channel 2 , WAPA-TV (7782) to Channel 4 , WIPR-TV (7783) to Channel 6 & WLII-TV (7784) to Chanel 11.
I have 2 identical S802 Androids boxes. On the first one I was able to load the PVR Stalker and sorted thing out. Working OK!!. On the second one I follow all the same steps. The PVR Stalker loaded fine but unfortunately the guide doesn't want to work. I uninstall the stalker and Kodi. Re-install both but still the guide doesn't want to load. Anyone that can help?? Appreciated!
