Results 1 to 10 of 15
    Apr 2015
    Problem in configuring iptv66
    Yesterday night I bought new activation from iks66. I had iks66 before also and just could change activation code and found working very fine.
    I already configures NFPF iptv on Mega 268 on Kodi and iptv stalker. I face problem with iptv66.
    I shall be thankful for guiding me step by step and also let me know, how configuration is different from NFPS
    Blackbear Blackbear199's Avatar
    only difference is server address
    http://66.iptv66.tv
    Please see the tutorials on individual add-ons in the Kodi Discussion. They are as close to step by step as you can get. You can aslo look at the stickies in the other private server forums here as well, especially the one for NFPS, as there is a lot of info there as well. See my sig for a good pdf that can also help as well.
    I agree dara but most don't even bother looking,they make another thread.usually I don't bother answering them but whats one more when there's already too many asking the same thing over and over again.
    Apr 2015
    I have NFPS and rocket codes also. I could configure both accurately and working fine. But some thing is wrong with server id. Please do double check. If it can go with IP address. Let me know.
    Quote Originally Posted by dilpuri View Post
    iptv stalker requires the server to be mw1.iptv66.tv and make sure you have send serial unchecked as well. You may want to link a new mac to make sure you are starting clean.
    Apr 2015
    On this website, https://iks66.tv/main/search
    I check my activation codes. Found codes active and when I change Mac address and fill the capcha figure and save. I get the message Mac already registered. I want to change it but it is not accepting change in Mac address. How I can amend MAC.
    It may be the format you are using. Are you using colons? Does the MAC start with 00:1a:78? Are the last 6 numbers 0-9 or a-f?
    Apr 2015
    I use " : " as I used to feed mac address in nfps.
  1. s1.iptv66.tv problem
    By hussydany in forum IPTV Private Server (IPTV66)
    Last Post: 01-11-2018, 08:29 PM
  2. Configuring the OFFICIAL IPTV66 ANDROID EMULATOR
    By dara in forum IPTV Private Server (IPTV66)
    Last Post: 02-09-2017, 03:51 PM
  3. Add-On for configuring IPTV66?
    By Undrcrwn in forum Kodi Discussion
    Last Post: 05-31-2016, 08:36 PM
  4. Help Configuring IPTV66
    By StudentOf33 in forum PVR Clients
    Last Post: 04-28-2016, 07:42 PM
  5. configuring ftv
    By kingcobo in forum Amazon FireStick & FireTV
    Last Post: 04-25-2015, 11:06 PM
