Results 1 to 9 of 9
Thread: problems
    problems
    This is from rocket forum, I have had NO help, maybe I am in the wrong place, but would like to get this working
    thanks
    jerry
    Hey
    New user, made a donation, received the email very soon after, and am attempting to connect and receive.
    New install on a linuxmint, 3.13.0-37-generic #64-Ubuntu SMP, on an Asus laptop.
    I have made attempts using a couple different methods, most have been referenced in these forums.
    Method 1
    Install Kodi, via apt-get install kodi kodi-pvr-stalker kodi-pvr-iptvsimple
    this brings in stalker version 0.8.3, from dvbken
    this version appears to connect, receive some info, then disconnects, and errors out
    apt-get remove kodi kodi-pvr-stalker kodi-pvr-iptvsimple
    Method 2
    Install Kodi, via apt-get install kodi, download the zip file for stalker, pvr.stalker.wind-0.8.3.zip, install from zip, select the file, and install
    this results in many errors, and does not connect to the server.
    Is there a wiki, sticky post, or some other available resource, that defines what is the CURRENT information as to what is required AND current as to the addresses that are required?
    There seems to be a need for a page that details the required info, how to change your MAC,etc
    Has there been discussion about a wiki
    Thanks for the effort in putting this out, I certainly do appreciate it, and will continue to support you, just need to have a little more documentation.
    I hope to be able to, either attatch or link to my logs.
    Thanks for the help
    mexjerry
    pastebin of the errors in Method 2 above:
    http://pastebin.com/NghhyVHL
    pastebin of my current errors:
    http://pastebin.com/Y1QNiQi5
    JFC, not a fsking reply, nor any help?
    At this point, maybe a waste of $10.00, THANKS FOR FSCKING NOTHING
    Blackbear Blackbear199's Avatar
    from you log....
    http:/portal.iptvrocket.tv
    its
    http://portal.iptvrocket.tv
    your missing a /
    also for kodi(considered a emulator) your suppost to use a 00:1A:78:XX:XX:XX mac.it will work with 79 like you have it buts were suppost to use 78.u will need to change it via the donation checker like you did when u first registered it.
    Blackbear199, thanks for the hints.
    The portal address has been corrected, also MAC is: 00:1A:78:XX:XX:XX
    I still have connection issues
    thanks
    jerry
    confirm your using iptv stalker or pvr stalker.
    from your log its pvr stalker
    so from your other post its shows its a iks66 donation
    so your setting should be
    server
    http://66.iptv66.tv
    mac as u registered
    delete the time zone,some say yes,some say no.i always delete(leave it blank).
    Quote Originally Posted by Blackbear199 View Post
    server
    http://66.iptv66.tv
    mac as u registered
    Blackbear
    Thanks for the help, I have successfully watched a TV program.
    Thank you for the help, much appreciated
    jerry
    mark this as SOLVED, thanks to a fellow user
  1. problems
    By billyg in forum IPTV Private Server (Rocket)
    Last Post: 06-05-2017, 03:10 AM
  2. New guy-problems
    By Nabil in forum Chit Chat Lounge
    Last Post: 11-06-2016, 05:23 PM
  3. stb emu problems
    By crusty197 in forum IPTV STB Emulators
    Last Post: 07-25-2016, 03:53 AM
  4. having set up problems
    By hog1945 in forum Mag 250 & Mag 254 IPTV Box
    Last Post: 07-23-2015, 10:15 PM
  5. epg problems
    By timezone12 in forum IPTV Private Server (Rocket)
    Last Post: 07-18-2015, 05:07 PM
