Page 13 of 13 FirstFirst ... 3111213
Results 121 to 126 of 126
  1. #121
    Quote Originally Posted by Drivium View Post
    By the way, oddly protective of your Kodi.
    No, just too many passwords, and way too many addons... its just under 1 gig, and even the userdata is about 350mb.
  2. #122
    not a member
    1. Disable the Send Serial Number in the Stalker Client or disable it.
    2. Make sure that you are not using the same MAC on any other device.
    3. Shutdown Kodi and any other device that may be using the same MAC.
    4. Go to this link and generate a new MAC. hxxp://www.hellion.org.uk/cgi-bin/randmac.pl?scope=global&oui=00%3A1A%3A78&type=mult icast. Replace xx with tt.
    5. Associate the new MAC with your donation. If it fails, repeat 3 and 4 until it accepts the MAC.
    6. Go to C:\Users\<LOGIN>\AppData\Roaming\Kodi\userdata\add on_data\pvr.stalker folder and open the settings.xml.
    7. Insure the connection_timeout value is at 60.
    8. active_portal value should be 0.
    9. id="mac_0" value will be the new MAC adress.
    10. Save the file.
    11. Restart Kodi and see if it now works.
  3. #123
    Everyone, this is going to sound like... why didn't I think about that? In the other thread about stopping the serial number from getting sent, Alucard found the lines where the portal credentials are established for IPTV Stalker when it gets called from iVue, or other external callers to it. So, in short, you can change one line in IPTV Stalker that will take the command from iVue, using the credentials set in Portal 1. You still will need to not set the "send serial number" as it does make junk for the server, but that's preventable as well from IPTV Stalker.
    It may be a good time to send out an update to IPTV Stalker, which can be used with iVue, but with Renegades as well.
    Here's the fix... Replace the addon.py in "special" Kodi/addons/plugin.video.stalker
    Attached Files Attached Files
  4. #124
    Here is the modified version of IPTV Stalker ... compatible with your valid linked mac and iVue! You don't need a modified addons.ini
    http://iptvtalk.net/showthread.php?7...Vue-compatible
  5. #125
    highly doubts high247's Avatar
    For always!
    This needs a sticky! You rock!
  6. #126
    For always!
    Worked mint.
  1. IPTV STALKER Authorization Failed or server down?"
    By jeshua251280 in forum IPTV Stalker (Video add-on)
    Last Post: 02-29-2016, 05:05 AM
  2. Replies: 4
    Last Post: 01-20-2016, 06:42 PM
  3. Fixing iVue Guide to work with IPTV Stalker ("failed authorization")
    By Nightrider13 in forum IPTV Private Server (NFPS)
    Last Post: 10-24-2015, 11:52 PM
  4. Replies: 3
    Last Post: 10-08-2015, 02:32 PM
  5. IVUE TV GUIDE "MAC" erro and IPTV STALKER updates stops it working
    By markie156 in forum IPTV Private Server (NFPS)
    Last Post: 09-16-2015, 07:45 PM
Tags for this Thread
