Page 3 of 40 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 391
  1. #21
    In the hills
    after you change the proper guide URL you must purge your kodi database in settings > TV > Clear Database, then restart kodi before it finishes loading the channels again.
  2. #22
    Jun 2015
    yes i do.
    Quote Originally Posted by psycon View Post
    I tried doing that earlier with no luck. Are there other settings that can affect the time? Or do I need to delete other Kodi databases?
  3. #23
    Others who use the Fire TV or stick have reported the same issue. It may be specific to those devices, and maybe due to how they are setting the time zone.
  4. #24
    Hi. Anyone else getting channel guide that starts with channel 18?
  5. #25
    In the hills
    if your channel guide isnt in color, and is all grey, you have something set up wrong and are only getting the NFPS provided epg data (it is grey as it does not support genre meta tags)
  6. #26
    In the hills
    I use a fire TV. no issues here... For the one or 2 people having one-off issues, it is most likely a user data entry mistake... or some kind of setting is wrong on their device.. They are always able to download the grabber and modify the code to try and compensate, but it likely wont help any if they have their settings wrong int he first place..
  7. #27
    Android World
    Just installed Kodi 14.2 helix on windows 10 and I followed the instructions to the T very nice works perfect thanks all .
  8. #28
    Jun 2015
    yes i do.
    My channels are grey with no color unless highlighted. I also still don't have the correct time. Did you make any adjustments to your time zone or are to already in the Eastern time zone? Did you have Simple Stalker installed before installing PVR Stalker?
  9. #29
    i do dkmow how to fix
  10. #30
    Jun 2015
    yes i do.
    I got the guide to the display the correct time zone by switching the XMLTV Preference to Provider Preferred.
    Now I'm working on getting the guide to display the correct colors.
  1. Replies: 5
    Last Post: 08-24-2016, 02:21 PM
  2. Replies: 6
    Last Post: 02-10-2016, 06:06 PM
  3. How to set up pvr.stalker.NFPS and have a Full EPG
    By psycon in forum Kodi Tutorials, Tips & Tricks
    Last Post: 01-31-2016, 11:33 PM
  4. How do i get full EPG for Stalker ?????
    By pgonzalez in forum Amazon FireStick & FireTV
    Last Post: 07-10-2015, 09:03 AM
  5. Replies: 3
    Last Post: 05-01-2015, 05:02 PM
