Page 1 of 33 12311 ... LastLast
Results 1 to 10 of 326
    Go here for new method: http://iptvtalk.net/showthread.php?1...r-Papiao-(New)
    Manual configuration:
    This tutorial assumes you already installed the IPTV Stalker.
    1. Verify M3U Server is enabled and set to Port 8899: Go to config-> M3U Server (tab over to right beyond Parental). You can click Start if you want, but just once is fine. Exit settings, go to Portal 1 and clear cache using the context menu. Click into the portal, and select "All" to load the channels. (May not actually be required for Server only operation)
    2. Go to the Add-on Browser and locate the "PVR IPTV Simple Client"
    3. Configure the client as follows:
    In General, Set Location to "Remote Path (Internet address)"
    Set "M3U PLAY LIST URL" to:
    http://localhost:8899/channels.html?portal=1
    "channels.m3u" can be used instead of "channels.html"
    Enable "Cache m3u at local storage"
    b. If you have a guide url, use the EPG Settings tab to enter the settings. [See above link for automated setup]
    4. Click OK, Enable PVR IPTV Simple Client
    5. Disable other PVR clients if previously enabled. Multiple clients can be used but you will end up with a blended channel list.
    6. Disable and re-enable Live TV. You should see channels load, then the EPG. If you don't see a load for the EPG, try "Reset the EPG database" from the TV-Settings page.
    7. If you don't get an initial load at all (i.e. no TV on main Kodi page), try exiting Kodi, and re-enter. This may take a few attempts.
    You should be able to leave Kodi, and on reentry, Kodi should be able to restart the LiveTV on its own. If you restart Kodi and the channels don't load, try disable/enable LiveTV.
    Don't forget to change the EPG Time Shift appropriate to your location. ********** is set at UTC+0.
    Don't forget to change the EPG Time Shift appropriate to your location. The data is set for Eastern Time (USA)
    So, since I'm on CST (Central Time), I should set it to -1.00? I've tried -1.00 and +1.00, but the EPG didnt change even after restarting.
    i cannot get past 1.0.7 iptv stalker
    got it.
    Quote Originally Posted by bubbs16 View Post
    Download this:
    https://github.com/esxbr/plugin.video.stalker/archive/master.zip
    System>Addons>Install from zip
    In the hills
    Quote Originally Posted by JLVines View Post
    This is a known issue with IPTV simple pvr, Try resetting Kodi's pvr database in settings > TV >Guide after changing your timzeone.
    Ideally someone can set up an xmltv custom grabber. maybe webgrab plus. to grab the data we need
    Ivue seems like it needs to be updated again, i am getting no program info for all channels again.
    Apr 2015
    I have a problem getting anything to work now,was working perfect yesterday today nothing,ive tried the guide Psycon/pocpoc put up to try to set it it up the new way but nothing,ive updated the stalker addon to 1.0.11 ive done the iptv simple client set up ,enabled it,disabled iptv stalker enabled/disabled live tv reset database etc but nothing is happening just a no programme information and no channels load,this is on my windows pc,
    ps. had my amazon fire tv working great as well yesterday with the ivue guide and stalker but today is empty nothing happening,i haven't updated the iptv stalker plugin addon on my fire tv yet so that may be the problem but I will wait to see if anyone can kindly help me figure out how to get this great addon working again,fingers crossed
    ps can someone just guide me as to which stalker I should disable/enable for this as this may be were im going wrong is it the 1.0.11 or the 0.6 dvbken one I need to disable confirgure correctly along with the simple client settings it driving me round the bend,sorry for the long post
    In the hills
    change url to
    http://tecbox.tv/repo/teciptvguide/stalker.xml
    . no need for ivue plugin
    Quote Originally Posted by psycon View Post
    change url to
    Will do. I was waiting for a fresh update to check on what timezone adjustment actually works. It may be mixed, unfortunately. I know there's a way to create your own epg as well, I think someone posted it here.
    In the hills
    disable PVR . Reset your pvr database and set to this url. then reenable... Works great for me with an offset of -3 for pacific. all data loading and proper times.
  1. Replies: 0
    Last Post: 04-07-2016, 09:31 PM
  2. Replies: 340
    Last Post: 10-28-2015, 12:30 AM
  3. Replies: 2
    Last Post: 07-21-2015, 05:24 PM
  4. Replies: 2
    Last Post: 07-01-2015, 04:59 PM
  5. INTEGRATE IPTV STALKER WITH PVR SIMPLE CLIENT & iVUE EPG GUIDE XBMC
    By farwoof in forum Kodi Tutorials Stickies
    Last Post: 06-12-2015, 01:21 PM
