Page 4 of 4 FirstFirst ... 234
Results 31 to 38 of 38
  1. #31
    Quick question, re check your mac address. Do you have any 8s or Bs. I mistook a B for an 8 and that caused me a lot of trouble until I identified my mistake. Double check your mac address and correct it in you donation if necessary.
  2. #32
    Yes I do
    Thank you so much tin man you are smart that's what my problem was thx so much
  3. #33
    that didnt do anything they dont even use that maybe because i redid your mac address with a different number and then put your old one back in oh well
  4. #34
    Banned
    Jul 2015
    I know you say it doesn't do anything, but worked for me on both boxes. I spent a few hours trying to get my box going when I 1st got it. As soon as that info was inputted it worked. Same thing with my second box. I tried without and with. It connects quickly after you input donation info. Just saying, people having problems connecting should try it......it can't hurt right.
  5. #35
    same with me, I checked auth box when we went to paid on TV Online model...worked for me
  6. #36
    no it may work but i dont know why it would think they dont even use that
  7. #37
    so many days after trial was over, I wasn't able to connect on Online model. All I did was check auth and enter user/pass and all was and still is good...
  8. #38
    They have not officially said to do that, but that would stop the problem of people not have a mag or AVOV box from creating a fake mac addresses not using the 78.
