delete and redo that app the tvonline one
I did that allready nothing I have seen that other people on here have had the similar problem could not connect but it doesn't say what they did to fix it so much for lug and play lol
look if thats true mac address from box and the url is right it should work go to tvonline setting and hit the first server and click red button on the remote
I have done that everything is right I have checked it to make sure I don't have to set anything up for Internet cause I'm hard wired it picks it up automatically
did you go to setting on tvonline and you have url click it and red button
Yes I did that buddy I have checked 3 and 4 times reinstalled TV online twice and rebooted my network streaming works why won't the server work can you check with someone and get back to me cause I'm stumped URLs is http://11.iptvrocket.tv/ that's what I have in URLs
try it one more time please
I tried loading it again asft nothing not connecting
I don't know if its the same as tv online box, but I wouldn't connect at 1st. I had read at another forum that they checked off the credentials box and put the email they used to buy donation as username and donation number as password. I tried and it worked for me right away. I bought another box since then, and did same thing. Worked right away.
the info he gave me is right has internet like i said two things could be wrong mac address is wrong he gave me which he got from top corner of the tvonline app or the url he gave me which is right that he gave me now he redid box and ran i few apps and they worked my only last question is did you buy the donation off the rocket site
