Page 1 of 4 123 ... LastLast
Results 1 to 10 of 38
    Yes I do
    Could some help a old feller out pls
    I have a new vixo 2 I have changed my MAC address at iks rocket I have put URL into avov and still no channels it's taken a long time to connect I have unplugged receiver to reboot and nothing thx team hope you can help me
    Yes I do
    I have that printed out and I followed that step by step and still nothing
    ok so you loaded tv online app look at think top right corner thats mac address you need copy that now did you go and setup that mac address ?
    Yes I do
    Yes I did I did that at iks rocket I printed the step by step and followed that and printed my donation report and the MAC address is in there am I missing something I have been reading all over trying what other guest have had trouble with and nothing
    what url did you use hope http://11.iptvrocket.tv/ like this
    Yes I do
    Http://11.iptvrocket.tv/ yes that's what I did is there something else I put in main settings
    small h ........ after that when you load it in think red button to start server and you should have tv
    Yes I do
    What red button I tried hitting when URL screen comes up nothing and I do have a little h it doesn't say in setup to hit red button ok I got you about the red button it just try to connect how long should it take everything is right at search my rocket it won't connect that's the trouble I'm having
    when in tvonline go to setting next click server one check it or click on it now box comes up where server url is and that use info then hit connect now if you see channels on right side your good go out and watch tv and see the mac address on top when you went to the site to load that info you use that address right and it said it was good to go
