Hi,
Can some help to set up Live TV in kodi app, I set with NFPS and works fine , But i check some vedio online to added http;// addess don't work ,
So please some one.
Hi,
So please some one.
you can only use kodi apps from the mickymart, thks...if it's an iptv service just enter the url in another portal..
Hi,
I am looking for other unpaid live tv and i am looking URL that i can put ,but i need step by step.
add kodi and do some google
have you checked the app store in your menu??
There are a lot of PVR clients you can add to Kodi. Just depends what you have. For example if you have a Cable Card you could tye Kodi to it. If you are only using IPTV then you could use IPTV Simple Client too and add your URLs to it.
