Results 11 to 20 of 31
Thread: avov tvonline
    menu>settings>ethernet
    it tell you on left top corner some kind symbol
    wiring avov
    do you fill in the areas in eternet box to hard wire the avov online ethernet box and ip address and net mask those spaces
    no, all you choose is DHCP or static...I suggest you choose DHCP, works well for most
    Moderator at Work
    Suggest you do a reboot by either cutting power Off/On or holding Off on remote for a few sec then choose Reboot from drop down, a reboot helps with many issues.
    did reboot theuduk what should i do next
    trying to connect to server 1 entered 1.iptvprivateserver.tv/ not connecting
    sigh....wrong url, use 11.iptvprivateserver.tv....pls read the tutorials, Sylvia..that is the correct url for NFPS server, hopefully that is where you made your donation
    i have not made a donation yet is there one you recommend
    Banned
    Jul 2015
    I have a tv online box and it works fine. I have NFPS Donation, but you really need to read. You are not even fully reading the help your getting on your own thread.....read. Everyone is willing to help. It just gets frustrating when people rush through it without putting the time in to read.
  1. AVOV TVonline+
    By a-team in forum aVOV TvOnline+
    Last Post: 03-22-2016, 01:52 PM
  2. APK for Avov tvonline+
    By Jadaca in forum aVOV TvOnline+
    Last Post: 12-16-2015, 12:50 PM
  3. Avov tvonline
    By OMARKAYAN in forum aVOV TVOnline
    Last Post: 12-12-2015, 07:32 PM
  4. Avov TvOnline vs Avov Vixo 1
    By master10 in forum aVOV TVOnline
    Last Post: 05-19-2015, 12:47 AM
