Click for Info about the add-on and how to install/use
Click for detailed tutorial about setting up PVR Stalker and Electronic Program Guide
To configure, from the Main Page, Select System > Add-ons > My add-ons > PVR clients.
Look for Stalker Client, and Click to bring up Add-on information
This is the version you should be on .... PVR Stalker (0.8.3)
Attachment 812
Click on Configure and select General
You can set up to 5 different portals. The Connection Timeout is defaulted to 5. You can set up to 15, but also can raise the value in the userdata > addons_data > pvr.stalker > settings.xml . We will configure Portal 1
Attachment 813
These two screen shots show a setup for NFPS using the FAKE Mac, and to use the 'psycon xmltv grabber' for an EPG
Attachment 815
For MAC Address, enter your MAC that had been linked to your donation. Your linked mac is
00:1A:78:xx:xx:xx , where the x's are Hex digits (0-9, A-F). The colons are required, and there is no letter 'oh'.
For Server Address, enter the IPTV Server that was assigned to your donation
NFPS - http://11.iptvprivateserver.tv
Rocket - http://11.iptvrocket.tv
IPTV66 - http://66.iptv66.tv
For Time Zone, leave as is, and leave Auth Credentials blank. These are not required.
For Guide, Select one of the following : Prefer XMLTV, XMLTV only, Prefer Provider, Provider Only
Attachment 814
If you select an external EPG, select Remote URL and enter one of the following
Valid EPG Links:
Please see the following site for more info:
http://**********
TBA: Links that will work for the built in PVR Stalker
nfps or rocket : https://papaio.tv/main/EPG/mac/00:1A:7x:xx:xx:xx/donation/xxxxxxxxxxxx/fname/<guide>
iptv66: https://iks66.tv/main/EPG/mac/00:1A:7x:xx:xx:xx/donation/xxxxxxxxxxxxx/fname/<guide>
Replace "<guide>" with the following:
NFPSF1 - English
NFPSF2 - English, non DST
NFPSF3 - Full
NFPSF4 - Full, non DST
Set a custom Serial Number in Advanced
- The Serial Number, Device IDs and Signature can be a combination of letters or numbers. Token is not currently required.
Click OK to save your settings. Click on Enable to enable the client.
Navigate to the Main Window, select Services > TV (or Live TV) > General
This is a screen shot of the TV Settings. Stalker Client must be Enabled in "My Addons". If you have issues with a load of channels, Clear Data, and Disable/Enable will sometimes correct the issue. Also, refer to the tutorial linked above.
Attachment 816
