Page 3 of 12 FirstFirst 12345 ... LastLast
Results 21 to 30 of 118
  1. #21
    starting with Kodi 16 Jarvis alpha2, full urls (including the trailing '/') must be used.
    NFPS - http://portal.iptvprivateserver.tv/stalker_portal/c/
    Rocket -  http://portal.iptvrocket.tv/stalker_portal/c/
    IPTV66  - http://mw1.iptv66.tv/stalker_portal/c/
  2. #22
    Apr 2015
    Sure
    Yes, that is me - I was looking for help and/or some direction with it. so answer is to upgrade my version of Kodi. Thanks will give it a try.
  3. #23
    Apr 2015
    Sure
    So I'm getting closer. I'm now running Kodi Jarvis 16 rc2. PVR client 0.9.7.
    I'm still getting an error when I try to download. log portion attached. Anyone know what error 794 is supposed to mean?
    21:20:47 290.677856 T:1475068928 ERROR: AddOnLog: Stalker Client: GetChannelGroupMembers: channel not found
    21:20:47 290.677979 T:1475068928 ERROR: PVR - GetChannelGroupMembers - addon 'Stalker Middleware:http://cod123.biz:88/stalker_portal/c/' returned an error: server error
    21:20:47 290.678070 T:1475068928 ERROR: PVR - GetChannelGroupMembers - cannot get group members from client '794': server error
    21:20:47 290.710144 T:1475068928 ERROR: AddOnLog: Stalker Client: GetChannelGroupMembers: channel not found
    21:20:47 290.710419 T:1475068928 ERROR: PVR - GetChannelGroupMembers - addon 'Stalker Middleware:http://cod123.biz:88/stalker_portal/c/' returned an error: server error
    21:20:47 290.710510 T:1475068928 ERROR: PVR - GetChannelGroupMembers - cannot get group members from client '794': server error
    lvpi2:~/.kodi/temp #
  4. #24
    enable debug logging
    http://kodi.wiki/view/Log_file/Advanced#Enable_debugging
  5. #25
    Apr 2015
    Sure
    Problem was solved, I just didn't see the channels until I did a "Clear data". So it is working. thanks!
  6. #26
    Jul 2015
    Since the new requirement of a serial number with NFPS; is it possible to get the built-in version working with it?
    I can't use the modified version (Stalker Client NFPS) because I'm using Android Lollipop which prevents the required .dll/.so from loading.
  7. #27
    Apr 2015
    The stalker does have serial number entry and I have tried to Add a 13 digit (even 15 digit) random serial number, but Stalker says "Unable to load channels", Are the device ID 1&2, signature, token, required? I have tried entering random numbers in that also and still says "Unable to Load channels"
    Anyone has gotten Stalker client to work after the serial number requirements ? please help
  8. #28
    Cross my heart and hope to die
    Quote Originally Posted by apun View Post
    I've tried numerous of times but failed the only thing working at he moment is ivue guide wth iptv stalker addon
  9. #29
    This is a tutorial thread. I'm deleting posts that are not configuration issues.
  10. #30
    Member Aids10's Avatar
    Oct 2015
    Hell
    Appears there are outstanding configuration issues;
    Followed guide exactly and are getting the following error-
    Stalker Client- Unable to Load Channels
    Using Latest-
    Kodi 15.2 Isengard
    Stalker Client 0.8.4
    Also, changed to a new MAC (first with server) and Serial at same time to no avail...
    http://iptvtalk.net/showthread.php?9...Stalker-Client
    Appreciate any help!
    FYI- I'm using http://66.iptv66.tv
  1. pvr stalker client (kodi built in)
    By hreynoso1 in forum EPG (epg.ninja)
    Last Post: 04-07-2016, 07:35 PM
  2. pvr stalker client (kodi built in)
    By hreynoso1 in forum PVR Clients
    Last Post: 04-07-2016, 02:22 PM
  3. Replies: 3
    Last Post: 04-05-2016, 09:18 PM
  4. PVR Stalker (Kodi Built-in) Set up tutorial
    By dara in forum PVR Clients
    Last Post: 03-06-2016, 02:48 AM
  5. Replies: 1
    Last Post: 01-06-2016, 04:44 AM
