Results 1 to 5 of 5
    Unhappy iVue TV Guide Authorization failed even with valid MAC address. Please Help!
    I am currently using IPTV Stalker app in Kodi, and recently I donated and added my Mac address to that application settings. Apparently everything seems to be working perfect. My problem is that I am also using other app called iVue TV Guide (that I love). Time ago before my donation, it was working fine, but now when I try select any TV show, it shows me an error message that “IPTV Stalker Authorization failed”. I have restarted it several times and also deleted the cache, etc. but the problem is still there. That problem is only happening to iVue TV app.
    I am not sure if I need to do anything else to make it work?
    Thank you...
    hello im new to this. where do you go to donate so you can get your mac address to log onto iptv
    looks like ivue hard codes the mac addys into addons.ini try this post here http://iptvtalk.net/showthread.php?6...0542#post50542
    It is very funny. I am new too and yesterday I was in the same boat than you. It is very difficult to know what steps you need to follow to make a simple donation.
    Well, I donated from this URL: http://iptvprivateserver.is
    Then you need to know what device you are going to use to watch the live TV channels. In my case I use Kodi on my Windows 10.
    After the donation, you need to know Mac address of the device you are using, in my case Kodi. Go to SYSTEM>SYSTEM INFO>NETWORK and copy the last 6 digits of your MAC address to use it later to register it and get the access.
    A very important step is this that you need to use as Mac address these 6 digits in the begging of your mac address, and put it together with your last 6 from Kodi: This is an example: (the first 6 digits should be always: 00:1A:78 and then your last 6 digits from Kodi: 01:02:03, so the final result must look something similar to this: 00:1A:78:01:02:03
    Here you are going to register your Mac addresss after your donation: https://papiao.is/main/search_nfps
    Finally, you have to open Kodi, go to VIDEOS>ADD-ONS>IPTV STALKER> RIGHT CLICK ON IT>ADD-ON SETTINGS>ENABLE MAC> AND PUT THERE YOUR MAC ADDRESS.
    That would be all.
    Final note: you need to install previously IPTV STALKER app in Kodi. You can search on YouTube about how to install it.
    Quote Originally Posted by nek666 View Post
    Actually it's all in the kodi files or tutorials section no need for youtube
  1. Replies: 4
    Last Post: 01-20-2016, 06:42 PM
  2. ITV Authorization Failed
    By GlennC in forum IPTV Private Server (Rocket)
    Last Post: 10-25-2015, 04:09 PM
  3. Fixing iVue Guide to work with IPTV Stalker ("failed authorization")
    By Nightrider13 in forum IPTV Private Server (NFPS)
    Last Post: 10-24-2015, 11:52 PM
  4. Authorization Failed Error - after installing Ivue
    By RidgeGuy in forum IPTV Private Server (NFPS)
    Last Post: 09-27-2015, 01:59 AM
  5. Replies: 125
    Last Post: 09-01-2015, 02:57 AM
