Page 3 of 16 FirstFirst 1234513 ... LastLast
Results 21 to 30 of 159
  1. #21
    I was unable to locate the "addons.ini" file on Windows 10. Is there any way to look into C: > Program Files (x86) > etc....
    Can someone help me...
  2. #22
    windows ten you could try just opening explorer and in there put %appdata%\kodi\ that should get you there then simply goto userdata addon data and modify the addons.ini file in there. i have no guides for this lot as yet as its not a common thing to do but ill try and get some in time
  3. #23
    Thanks For The Info. I Just Need A Bit More Help.
    My Mac Code Has The Words NULL SERIAL and PASSWORD In It, Is That
    Correct? mac%22%3A+%22%2C+%22SERIAL%22%3A
    When I decode I don't see a mac address I get this: mac": "",
    I even tried with just mac%22%3A%22%2C and get the same mac": "",
    I went to the site you gave http://www.url-encode-decode.com/[/url]
  4. #24
    Hello Can You Please Help Me, I Don't Mind Giving You My Mac Address, I Just Want To Get My Ivue Working With Stalker.
  5. #25
    Member dh8389's Avatar
    Jul 2015
    Scotland
    Maybe because I have paid for my live TV, but when I select iVue it will come up authorisation error. But when I select another channel it works fine. I don't use iVue but I hope you guys integrate for a better looking TV guide.
  6. #26
    Banned
    Apr 2015
    yes I do
    Quote Originally Posted by bobbywash View Post
    Just remember that you are only changing a few digits so you can copy more to get those digits defined and isolated. If you shorten what you enter into the decode site you can get it down to something like this after it is decoded:
    ": "00:1A:79:10:10:10", "
    this segment was like this before decoding
    %22%3A+%2200%3A1A%3A79%3A10%3A10%3A10%22%2C+%22
    In my case I changed 79 to 78 and added the correct last 6 digits (into ": "00:1A:79:10:10:10", ") and re-encoded it. Then I used the original string above in the search and replace function. One more step was needed in that I reset the iVue database to get rid of the old MAC. Then restarted and everything was working right.
  7. #27
    Jul 2015
    On android where do you find the file??
  8. #28
    Banned
    Apr 2015
    yes I do
    Quote Originally Posted by rhabr View Post
    I just tried to find the file on my one android device and had no luck. I suggest you go over to one of these sites if nobody helps you:
    http://forums.tvaddons.ag/
    http://kodi.wiki/view/Userdata
    They have an Android thread so they should know what the directory structure looks like.
  9. #29
    Thank you, this worked for me. Of course, I had to do a global replace of iptvprivateserver for iptvrocket! But it is now working.
  10. #30
    The path is .../Android/data/org.xmbc.kodi/files/.kodi/userdata/addon_data/script.tvguidetecbox/addons.ini
    You may need root access, and the ability to read hidden files and folders. You can use one of the various file managers out there to get to the file. Copy it, and then you can work on it outside of Kodi. You can put a renamed and reworked .ini the same place, or in a place where it might be easier to find.
  1. IPTV STALKER Authorization Failed or server down?"
    By jeshua251280 in forum IPTV Stalker (Video add-on)
    Last Post: 02-29-2016, 05:05 AM
  2. Replies: 4
    Last Post: 01-20-2016, 06:42 PM
  3. Replies: 3
    Last Post: 10-08-2015, 02:32 PM
  4. IVUE TV GUIDE "MAC" erro and IPTV STALKER updates stops it working
    By markie156 in forum IPTV Private Server (NFPS)
    Last Post: 09-16-2015, 07:45 PM
  5. Replies: 125
    Last Post: 09-01-2015, 02:57 AM
Tags for this Thread
