Page 2 of 16 FirstFirst 123412 ... LastLast
Results 11 to 20 of 159
    Android World
    Well your the boss lets hope you keep your word.
    Hi i am new and I need your help in getting my Ivue up and running again...
    how you fix ivue TVguide if you using a android boxset ? please help i paid for IPTV and still get error loading channels on ivue ; ;
    Banned
    Does this really work? if so, how can I change this on Firetv kodi. Any easy way?
    How can i do this on my amazon fire stick with Kodi?
    Last edited by dara; 08-10-2015 at 06:04 PM. Reason: please don't c/p the original post.
    IVUE fix on my fire stick
    Hi hve iptv stalker and IVUE on my fire stick and have donated for IPTV stalker and my ivue wont work now so was just wondering how to get ivue and stalker back working together? thanks in advance!
    For those with any android box, the best thing to do is get the addons.ini file from its location, and edit it on a PC, and then sideload it back to the previous location, or to another location where you can find it with a local path. Probably should change the name to addons2.ini and make the change to "custom" as well.
    Hi dara, i have a fire stick as i said above could you be more specific on how to locate the file, get it, change it and then put it back im a bit of a newbie! thanks alot
    Android World
    Good luck on fixing the loop hole.
    Quote Originally Posted by fonzy1888 View Post
    I'll try to get a path listed here. It may be harder for some if you don't have root access.
  1. IPTV STALKER Authorization Failed or server down?"
    By jeshua251280 in forum IPTV Stalker (Video add-on)
    Last Post: 02-29-2016, 05:05 AM
  2. Replies: 4
    Last Post: 01-20-2016, 06:42 PM
  3. Replies: 3
    Last Post: 10-08-2015, 02:32 PM
  4. IVUE TV GUIDE "MAC" erro and IPTV STALKER updates stops it working
    By markie156 in forum IPTV Private Server (NFPS)
    Last Post: 09-16-2015, 07:45 PM
  5. Replies: 125
    Last Post: 09-01-2015, 02:57 AM
Tags for this Thread
