Results 1 to 10 of 18
Thread: Internet Speed
    Internet Speed
    Hey Guys would like to hear how the emulator is running with lower internet speeds?
    Thanks I have read that already. I was wanting to here from somebody running at 1.5 down as to how it was running. Thats what i have and vod works great but the channels freeze every 10 secs .
    good question my does not get much channels anymore or if u leave one channel and try to go back u can never get the channel so I got 5mps or bev internet but when channels works they work great so to me is it my end or their?
    I get all the channels just all of them freeze. I read else where guys with very fast internet speeds are complaining of freezing as well. Would like to here from some body with 1.5 download and that the emulator is running great so i know ive got to keep playing with my set up.
    well I don't getmuch so is it my box then would like to know also
    Have you tried deleting everything and reloading the emulator and settings?
    Thanks I have read that already. I was wanting to here from somebody running at 1.5 down as to how it was running. Thats what i have and vod works great but the channels freeze every 10 secs . if on Ethernet cable try wifi or use a static ip address even try dns 8.8.8.8. you may find something that works
    TV Addicted xbmcbg's Avatar
    Jun 2015
    xyz
    The problem with you is not the only one :
    1 ) Your Internet is a lower limit to operate IPTV
    2 ) emulator further increases freezing
    If you have the opportunity to borrow MAG box (the only box which does not use an emulator ) and visually check whether the situation will be better.
    Do not forget to do what asft recommend to you.
    Thanks for the ideas guys. I tried to switch to wifi but when i do the emulator does nothing?? Is there a setting i need to change or need to reload something??
  1. internet speed?
    By TJP52 in forum aVOV VIXO 2
    Last Post: 04-06-2017, 03:20 PM
  2. internet speed ?
    By shmed in forum aVOV TvOnline+
    Last Post: 02-20-2016, 11:53 PM
  3. Speed internet
    By eduar1069 in forum IPTV Private Server (Rocket)
    Last Post: 11-17-2015, 04:04 AM
  4. internet speed
    By aevt628 in forum IPTV Private Server (NFPS)
    Last Post: 09-23-2015, 04:20 AM
  5. Internet speed
    By macgyver01 in forum aVOV TVOnline
    Last Post: 06-11-2015, 04:57 AM
