Results 1 to 10 of 14
    Fire tv or Mag254
    Hey guys need some suggestions. I want to use vod but I would also like something can also do xbmc. I have a ouya right now I like it but I would like something that can do vod if I could get one unit that could do both that would be great instead of having multiple units. What do you guys suggest.
    Anyone knows if the fire tv can do both?
    I can tell you the fire tv specs are way better, not sure if it can run it. But I am sure someone will figure it as its a great box.
    Jan 2015
    fire tv can do both live iptv and xbmc
    very true can work on both
    Canada
    Running Fire TV box using both and it rocks. Why not use your Ouya for it too? The set up for Ouya will be the same as fire TV side load the stb emulator and MX Player and your good to go.
    I'm running both and it is awesome. kare is correct, the specs are very good too! Very easy to set up. I am very pleased with it.
    where can I find a how to to get iptv on my fire tv box ,like to try it , have kodi on it right now
    Member Bluefly's Avatar
    Jan 2015
    I have both a fire tv and a MAG254. I love them both and they both work great!
    Quote Originally Posted by 2wire View Post
    This would be considered highjacking a thread.... Look in google play for the emulator its easily accessible.
    Quote Originally Posted by Bluefly View Post
    If you had to pick one of the two which one would you choose and why?
  1. Fire TV Stick and Fire TV - HD channels jump/skip?
    By rocket77 in forum Amazon FireStick & FireTV
    Last Post: 09-08-2018, 05:00 PM
  2. Replies: 0
    Last Post: 08-21-2016, 01:47 AM
  3. Replies: 1
    Last Post: 01-27-2016, 02:54 PM
  4. fire-tv-stick-may-receive-update-to-fire-os-5-tomorrow
    By Marley in forum Amazon FireStick & FireTV
    Last Post: 10-21-2015, 09:08 PM
  5. Replies: 0
    Last Post: 07-28-2015, 05:05 AM
