Clive... IPTV Stalker working for you with your MAC?
Guess I'll give it a rest for now !!! Getting too frustrating.
Only hope I can get some usage out of it before my donation runs out in 363 days !!!!
I tried it with IPTV Stalker briefly but still no joy....Maybe you can give me some basic parameters and I'll try before I give up for the night!!!
Re the PVR issue...all other PVRs disabled.
Re the DNS issue.....My router does have a smart DNS number inputted ...
you don't need your donation number and i never put any thing there
Then it comes back with an error 10060 scrolling at the bottom.
The scroll says "failure to make connection because......." the it disappears.
Please check dara's tutorial
http://iptvtalk.net/showthread.php?5...5666#post45666
If I follow the tutorial and do not enter serial/ID number then it says "URLopen error"
If you are still trying to get IPTV Stalker going, with that serial number error, uninstall it and delete its folder in the userdata>addon_data. That will also get rid of the cache, so basically you are starting from fresh, without having to put in that number you tried before. Reinstall from the source (github), and reconfigure. If you get that again error again, you may need a relink a different MAC, as you sent a fake serial number to the server, and it may have stored it against the MAC... this is a theory based on a post from a very technical super-mod over on the other site.
edit:
I did a search on that error... it may be an issue with your network or Kodi itself just at first glance. I've been assuming you aren't running anything like a proxy or VPN.
look at this vid... clearing the cache properly ususally does the trick:
Code:https://www.youtube.com/watch?v=Qfu-vN9cbtA
Hi Dara,....VPN is turned off, only gets turned on when I need it.
I'll work on the other stuff when I finish my Saturday morning runarounds !!!
I'll report back later.
Thanks for sticking with it.
