@clive622, have you tried the connection timeout increase, via the settings.xml in your "userdata > addon_data > pvr.stalker" folder?
Yes Dara, I had used the other version 0.8.2? and increased to 60. I had also manually increased to 100 by way of userdata folder in version 0.8.3
Will attempt again.
Still not connecting after editing settings .xml
Hi.....another noobie here:
I made a donation in papiao...donation has been assigned and they gave me a username and password...the email says the IPTV Portal is 11.iptvportal.tv, and the mac adress starts with 00:1A:79.
Installed the new Kodi 15...and downloaded pecaquito's mod (also tried it with the stalker client in this release).
The configuration is:
MAC Address 00:1A:79:xx:xx:xx (This agrees with listing in papiao)
Server Address 11.iptvportal.tv
Time Zone Europe/Kiev
Auth Credentials
Login (donation #)
Password (donation #)
Guide
Preference Prefer XMLTV
XMLTV
Scope Remote URL
Remote URL hxxp://is.gd/NFPSFD
Advanced
(All settings blank)
I also manually modified the settings.xml to 60...When I start Kodi, it tells me "Unable to Load Channels"...It was working during the trial...
Help....thanks
same here...tried the cache.xml and TV* db files too....
Thanks...sorry...will try to open a new thread....Darkside told me in pm to go to FTAbeta...there, I read a similar problem and they told the member to ask the question here, which is why I did it...
Clive, since you did fresh installs, I'm assuming you don't have any other PVRs up, which could cause issues.
I might be reaching, but are you using your ISP's DNS? I use google on my router (8.8.8.8 , 8.8.4.4). I know it worked before, but that was with 1. not 11.
