Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 43
  1. #21
    Quote Originally Posted by fireman View Post
    Has the connection timeout been extended?
    Timeout set to 60 with installed 8.2 client. No joy. TX
  2. #22
    Quote Originally Posted by stuygang View Post
    Glen I was having the same problem, read on another thread that the person inputted all the inf0 into port 2 and it worked. I tried it and it also worked.
    Tried that too. No joy but thanks.
  3. #23
    Quote Originally Posted by moye101 View Post
    make sure that there is only 1 active portal.
    Confirmed without success. TX.
  4. #24
    Quote Originally Posted by Sandiver View Post
    why not us the windows pc control panel to remove kodi (be sure and check mark to delete profile as well) and install the latest and greatest kodi 15, pvr stalker is included and the connection timeout issue is fixed. just enter your info and go. if you want to specify a guide do that later first see if you get tv.
    I installed 15 over 14.2. Can anyone else confirm the same problem without going to a fresh install? I'd hate to start from scratch again. Thank you.
  5. #25
    Glenn, what box are you using, and if android, are you rooted? Just want to understand where you are "at".
  6. #26
    Windows 7 home professional with latest KODI release. TX
  7. #27
    Thanks. I have 14.2 on my Windows 7 partition, and will check if I have issues on that when I do configure it after upgrading to 15.0. I'm not having any issues with Win 8.1 and the Kodi 15.0.
  8. #28
    @dara
    Do you suppose that my creating a MAC address with the link on this forum rather than using my true PC MAC address could cause this? My understanding was no.
  9. #29
    Quote Originally Posted by GlennC View Post
    @dara
    It could be that the MAC you created maybe corrupted on the server. I'd suggest creating a different one, making sure that it still starts with 00:1a:79, and maybe going all lower case, because I know that one program does automatically that before sending your mac to the server.
  10. #30
    Worth a try but no joy.
    Maybe try a clean installation?
  1. Unable to load channels
    By karateman1 in forum IPTV Private Server (NFPS)
    Last Post: 03-30-2016, 12:42 AM
  2. unable to load channels
    By fillup60 in forum IPTV Private Server (NFPS)
    Last Post: 03-24-2016, 12:06 PM
  3. Unable to load channels
    By JD95 in forum PVR Clients
    Last Post: 03-06-2016, 07:02 PM
  4. unable to load channels ...
    By sbdhulk in forum IPTV Private Server (Rocket)
    Last Post: 02-03-2016, 01:54 AM
  5. Unable to load channels
    By Hank Venture in forum IPTV Private Server (NFPS)
    Last Post: 02-02-2016, 09:23 PM
