Changed my video signal on my 254 to 1080p and now it wont let me in to change back. logo comes up after reboot, then says not supported. Tried on different tvs with no luck. Any answers, thanks
As it reboots press the button with three lines and dots see if that gets you in to settings, if not try the RCA cables.
Try this
Use the RCA cable that it came with, then set your tv to that RCA setting then once you plug in your Box hit the menu button right away and set the Video to NTSC toi 1080i then scroll down to save settings or something like that then with the right arrow button it will give you the option to save it and from there it will reboot and you can now go into the HDMI settings as it should boot up normally
Thanks so much guys, got it going again, but are you sure on the 1080i ,I tried that and it was still a no go. Went back to 580 or something like that and it worked, but still not full screen. Just want to be sure before I screw it up again. I would like for it to fit my screen. Thanks again
on remote bottom left corner will size it
