Adapting the application to work with Smart Android TVs
1. Install Sideload Launcher - Android TV / Android phoneusing the log with the profile you use the TV and choose to install it. This application makes it through it can open the "invisible" applications.Code:https://play.google.com/store/apps/deta[/url] ... cher&hl=en
2. Install App Backup & Restorewhich will be able to backup .apk file the application on your Android TV box/Android phoneCode:https://play.google.com/store/apps/deta ... ckup&hl=en
3. Install apk file STB emulator app from your Android TV box/Android TV to your TV via download and save into flash drive, send a mail to open using your TV, or with this app Air-Share & Air-Launchto install the Android TV/Android phone and TV and connect with each otherCode:https://play.google.com/store/apps/deta ... gloo&hl=en
Following this description you may:
- to use the ANDROID phone in place of the ANDROID STB
- to install Chrome browser, KODI and others. applications that are not in store, or are in closed platforms stores
Successfully installed STB emulator and KODI on Toshiba, Samsung, Sony, Philips and Sharp Smart TVs .
Warning Use these instructions at your own risk !!!!!
