I am using the same url on hers as I am on mine which is 1.iptvrocket.tv. By "redo it" do you mean to factory default? I have done that 3 times already
try 1.iptvprivateserver.tv or also 11.iptvrocket.tv
after you fac defaulted did you also update the box??
Yes I updated to r11 and I also tried 11.iptvrocket.tv. I will have to try the 1.iptvprivateserver.tv tomorrow. Thanks
if dont work try this http://iptvtalk.net/showthread.php?5...reset-your-box
also make sure it's still booting to NAND...
Here I am again. I have defaulted twice, software updated did step by step set up again reboot device and when it should go to main menu the blue bar comes up and when the yellow starts I get authentication required. I checked my mag and used the exact same things on my daughter set and I still get that message on hers. Mine is working fine. What can I do. Everything was fine until we had a power surge.
Try contacting Informir support. You'll find the info on there website. There support is very good.
last thing make sure you have internet
