Results 1 to 10 of 16
    Jul 2015
    Help with setting up IPTV Stalker in Kodi....getting HTTP Error 404.
    I donated to rocket, I insert my MAC address in the field. Done. Then....
    I have XBMC Gotham, so I upgraded to Kodi Helix and fixed the addon issue. Then....
    I go to apply the MAC address and URL http://1.iptvrocket.tv/ with a problem with HTTP Error 404: Not Found.
    Then I tried: 1.iptvprivateserver.tv same problem.
    I'm stuck now. Help please?
    Thank you.
    For IPTV Stalker, the correct server URL is portal.iptvrocket.tv. As far as we know the MAC isn't yet being validated, but make sure the first six are 00:1A:79. For now, a reset to Defaults will connect you to the iptvprivateserver.tv
    Jul 2015
    Thank you that URL did it! I'm not sure if MAC is required or not when finalizing donation but I inputted. I'm scared removing the MAC will not allow me to watch anymore so I left it. I did not input it in IPTV Stalker though, just left that field untouched. Maybe it's server side verification.
    Jul 2015
    What is the new url? I'm getting urlopen timed out now..
    Quote Originally Posted by contentryder View Post
    There is no specific new URL for IPTV Stalker. Keep trying to connect, because there is no configuration fix for the timeout issues, yet.
    TV Addicted xbmcbg's Avatar
    Jun 2015
    xyz
    Thank you.
    If you really need help on XBMC/KODI and you want someone to help you without having to guess, you need to attach debug log. Тhat will help us to localize the problem
    http://kodi.wiki/view/Log_file/Easy
    If you are using the Kodi.tv guys, don't mention that you are using IPTV Stalker ... they will ignore it as it is not an 'approved' add-on. PVR Stalker is though. The 404 issue is primarily a DNS or site issue... meaning the address is not being resolved, or the site isn't up.
    Jul 2015
    Is this why I no longer have any channels listed under IPTV Stalker? Should I instead download PVR Stalker? Thanks for all the info here
    Quote Originally Posted by pairughdocks View Post
    Please stay to topic. The reason you aren't getting channels with IPTV Stalker has nothing to do with the Kodi app, and PVR Stalker is now available built-in on Kodi 15.0 and beyond. We are discussing the 404 issue, and properly configuring IPTV Stalker. It's now assumed that you need a paid donation/rocket/route that has a valid MAC associated with it.
    Jun 2015
    In the configuration for Stalker Client, what entry should be made in Login/ password. I have a donation with papiao.is, I know what goes in password, but I'm unsure about the login. I'm getting " unable to load channels" . Ive configured the rest correctly to the best of my knowledge. Can anyone help please. Thanks
  1. Kodi Stalker Client URL forwarding http ?
    By coolsatri in forum Kodi Discussion
    Last Post: 01-15-2017, 11:45 PM
  2. stalker Http error
    By mikeyyy1994 in forum IPTV Private Server (IPTV66)
    Last Post: 02-16-2016, 09:46 PM
  3. Problems setting IPTV Stalker Kodi 15.0
    By rlant in forum IPTV Private Server (NFPS)
    Last Post: 09-05-2015, 12:55 PM
  4. How to setup Rocket Server IPTV Stalker (Getting HTTP 404 error)
    By bloodhod in forum IPTV Private Server (Rocket)
    Last Post: 07-18-2015, 02:38 PM
  5. Kodi IPTV Stalker 403 Error
    By senrab in forum IPTV Stalker (Video add-on)
    Last Post: 07-02-2015, 10:39 PM
