Results 1 to 7 of 7
    Junoir Member me2downhere's Avatar
    Amazon Fie TV connection timeout settings
    Can anyone help me how do you change the connection timeout on firetv to connect to server for iptv i changed it in my windows how o you find it on fire
    Nevermind got it all figured out
    that was ez good for you
    Alot of reading and now its a piece of cake to change the number in the settings if anyone else needs help on the matter I can give them the list to figure it out
    Jun 2015
    The important part to know is that you need to have root access to the device in order to make the change.
    Jun 2015
    Quote Originally Posted by me2downhere View Post
    ya I wouldn't mind the list to have a look see.....
    The solution is the same on android.. Install ES file explorer.. In ES, enable hidden files and folders in settings..... then go to /android/data/files/org.xbmc.Kodi/userdata/addon_data/pvr .stalker/settings.xml
    view the file then hit menu to edit.connection is on top of list change the timeout to 100 then save
  1. Connection Timeout
    By dottidot in forum IPTV STB Emulators
    Last Post: 12-24-2016, 04:48 AM
  2. Getting Timeout for about 2 hours now.
    By srcaptain in forum IPTV Private Server (IPTV66)
    Last Post: 06-05-2016, 07:01 PM
  3. URL timeout error
    By kingkong1 in forum IPTV Stalker (Video add-on)
    Last Post: 03-13-2016, 02:21 PM
  4. timeout fix for stalker
    By me2downhere in forum IPTV Stalker (Video add-on)
    Last Post: 07-16-2015, 07:08 AM
  5. site timeout
    By alphablondy in forum Helps us Improve!
    Last Post: 03-30-2015, 02:57 AM
