Page 3 of 3 FirstFirst 123
Results 21 to 30 of 30
  1. #21
    Member superiorfox's Avatar
    happened to me last night all i did was close it and open it a few times and it fixed its self.
  2. #22
    well for me adding this line=<setting id="connection_timeout" value="75" /> to the plugin.video.stalker settings.xml folder and adding the 75 to pvr.stalker settings.xml folder working for NOW on pc and my galaxy s5 rebooted them a few times and loaded fine
    best help i can give for now
    by the way credit goes to dara for telling us what the problem was but for us to figure it out
  3. #23
    Jun 2015
    Any idea how to perform this on the Kodi for Raspberry Pi?
  4. #24
    Jun 2015
    I'm not quite sure how to change the timeout on the Raspberry Pi (using Kodi/OSMC).
    It appears I am on IPTV Stalker version 1.0.18. Screen Shot 2015-07-07 at 6.33.14 PM.jpg
  5. #25
    Quote Originally Posted by Nightrider13 View Post
    There isn't a timeout setting for IPTV Stalker, at least in the native settings.
  6. #26
    Jun 2015
    Any idea where I might find that settings.xml file for IPTV Stalker for Kodi on Raspberry Pi? The only .xml i see is a "addon.xml" under the kodi/addons/ area.
  7. #27
    Oct 2015
    I too just made a donation to IPTV66, and I am getting cannot load channels error.
    Here is my configuration:
    <settings>
    <setting id="active_portal" value="0" />
    <setting id="connection_timeout" value="100000" />
    <setting id="device_id2_0" value="" />
    <setting id="device_id2_1" value="" />
    <setting id="device_id2_2" value="" />
    <setting id="device_id2_3" value="" />
    <setting id="device_id2_4" value="" />
    <setting id="device_id_0" value="" />
    <setting id="device_id_1" value="" />
    <setting id="device_id_2" value="" />
    <setting id="device_id_3" value="" />
    <setting id="device_id_4" value="" />
    <setting id="guide_preference_0" value="0" />
    <setting id="guide_preference_1" value="0" />
    <setting id="guide_preference_2" value="0" />
    <setting id="guide_preference_3" value="0" />
    <setting id="guide_preference_4" value="0" />
    <setting id="login_0" value="" />
    <setting id="login_1" value="" />
    <setting id="login_2" value="" />
    <setting id="login_3" value="" />
    <setting id="login_4" value="" />
    <setting id="mac_0" value="00:1A:79: ( )" />
    <setting id="mac_1" value="00:1A:79:00:00:00" />
    <setting id="mac_2" value="00:1A:79:00:00:00" />
    <setting id="mac_3" value="00:1A:79:00:00:00" />
    <setting id="mac_4" value="00:1A:79:00:00:00" />
    <setting id="password_0" value="" />
    <setting id="password_1" value="" />
    <setting id="password_2" value="" />
    <setting id="password_3" value="" />
    <setting id="password_4" value="" />
    <setting id="sep1" value="" />
    <setting id="sep1_0" value="" />
    <setting id="sep1_1" value="" />
    <setting id="sep1_2" value="" />
    <setting id="sep1_3" value="" />
    <setting id="sep1_4" value="" />
    <setting id="sep2_0" value="" />
    <setting id="sep2_1" value="" />
    <setting id="sep2_2" value="" />
    <setting id="sep2_3" value="" />
    <setting id="sep2_4" value="" />
    <setting id="sep3_0" value="" />
    <setting id="sep3_1" value="" />
    <setting id="sep3_2" value="" />
    <setting id="sep3_3" value="" />
    <setting id="sep3_4" value="" />
    <setting id="sep4_0" value="" />
    <setting id="sep4_1" value="" />
    <setting id="sep4_2" value="" />
    <setting id="sep4_3" value="" />
    <setting id="sep4_4" value="" />
    <setting id="serial_number_0" value="" />
    <setting id="serial_number_1" value="" />
    <setting id="serial_number_2" value="" />
    <setting id="serial_number_3" value="" />
    <setting id="serial_number_4" value="" />
    <setting id="server_0" value="66.iptv66.tv" />
    <setting id="server_1" value="127.0.0.1" />
    <setting id="server_2" value="127.0.0.1" />
    <setting id="server_3" value="127.0.0.1" />
    <setting id="server_4" value="127.0.0.1" />
    <setting id="signature_0" value="" />
    <setting id="signature_1" value="" />
    <setting id="signature_2" value="" />
    <setting id="signature_3" value="" />
    <setting id="signature_4" value="" />
    <setting id="time_zone_0" value="Europe/Kiev" />
    <setting id="time_zone_1" value="Europe/Kiev" />
    <setting id="time_zone_2" value="Europe/Kiev" />
    <setting id="time_zone_3" value="Europe/Kiev" />
    <setting id="time_zone_4" value="Europe/Kiev" />
    <setting id="token_0" value="" />
    <setting id="token_1" value="" />
    <setting id="token_2" value="" />
    <setting id="token_3" value="" />
    <setting id="token_4" value="" />
    <setting id="xmltv_path_0" value="" />
    <setting id="xmltv_path_1" value="" />
    <setting id="xmltv_path_2" value="" />
    <setting id="xmltv_path_3" value="" />
    <setting id="xmltv_path_4" value="" />
    <setting id="xmltv_scope_0" value="0" />
    <setting id="xmltv_scope_1" value="0" />
    <setting id="xmltv_scope_2" value="0" />
    <setting id="xmltv_scope_3" value="0" />
    <setting id="xmltv_scope_4" value="0" />
    <setting id="xmltv_url_0" value="" />
    <setting id="xmltv_url_1" value="" />
    <setting id="xmltv_url_2" value="" />
    <setting id="xmltv_url_3" value="" />
    <setting id="xmltv_url_4" value="" />
    </settings>
    where the ( ) is the MAC address for my donation.
    I am running 15.2 kodi on windows 10..
  8. #28
  9. #29
    Oct 2015
    Quote Originally Posted by big dady View Post
    unfortunately it didnt work.. my Stalker is running0.85 on this version of KODI, do you think it makes a difference?
    Does 00:1A:79 or 00:1A:78 matter when setting up MAC?
    edit: it works using the video, I just had to reinstall KODI and use the one in the video to get it to work!
  10. #30
    If you're using kodi 78 is the one to use
  1. If you can't get stalker load channels....
    By asesinopr in forum IPTV Private Server (NFPS)
    Last Post: 03-15-2016, 12:23 AM
  2. Unable to load channels Stalker
    By ducksauce88 in forum Kodi Discussion
    Last Post: 01-11-2016, 07:39 PM
  3. Stalker unable to load channels
    By fastrick in forum PVR Clients
    Last Post: 11-21-2015, 06:14 PM
  4. Stalker won't load channels?
    By input80 in forum Google Android Phones
    Last Post: 07-04-2015, 07:18 AM
  5. Is there a fix for this?? ipt stalker channels can not load
    By tinydread in forum IPTV Stalker (Video add-on)
    Last Post: 06-10-2015, 01:14 PM
